Results 1 to 8 of 8
    Dec 2018
    Czech Republic
    Default Ryker won't start - P2101 Throttle Actuator Ctrl Motor Circ Range/Perf
    Beginning of 2022 season is nightmare, I just made one short run and after that I am not able to start my ryker. Power vision display fault code P2101 - Throttle Actuator Ctrl Motor Circ Range/Perf. It is quite specific but there can still be several reasons, does anybody faced the same issue?
    I contacted my dealer (very small one) but they lost mechanician so their service is currently out of business. Other dealer is booked till mid of May...
    Nov 2016
    Upstate NY
    Get rid of the PowerVision tuner. Go back to stock and see if it fixes the problem. The ryker has great performance without an EFI tuner.
    2021 Sea to Sky RT , Highland green
    Dec 2018
    Czech Republic
    I just used PV as a diagnostic tool, my Ryker is currently on stock
    Dec 2013
    Quote Originally Posted by Fixxxer View Post
    But is the PV connected at all?? . If so, disconnect it completely & see if the problem goes away.
    That said, I don't believe we've seen any similar issues reported here on Rykers, not yet anyway...
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Nov 2021
    Alberta
    Have you made any headway on this? I just started having the same issue.
    Oct 2021
    Ontario
    Check your battery. I can't say for a Ryker, but low voltage can throw all sorts of fault codes.
    Have had this happen on other machines.
    Dec 2018
    Czech Republic
    In my case it was issue with throttle valve - it was blocked by piece of fabric which was sucked in by my inattention...
    Sep 2017
    Durham,Maine
    Thank you for your update!!
    2012 RTL , Pearl
