Results 1 to 13 of 13
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Default Anyone tried Flasher switch profile enlargement for easier operation?
    Flasher switch profile enlargement for easier operation.
    I have difficulty operating the flasher switch due to a damaged thumb.
    Its still there but no movement in the last joint.
    Has anyone made something you can fit to make the button a little larger, higher profile maybe.?
    Ideas?
    Sep 2015
    Chilliwack, BC. Canada
    You may want to explain a bit more....what flasher, 4-way or turn signal?
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Feb 2022
    New Zealand
    Flasher - turn signal - indicator - going lefty - going rightly.
    I want to build up the profile more so I can more easily move it.
    My thumb and gloves.
    I cant get hold of it to move it. Howzatt
    Try moving it with a gloved stick and you will now.
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    I don't know, If I am reading this correctly, but can you push a stick?, then the solution could be quit simple, drill a small hole, in the top of the switch, and let someone with a lathe turn you a stick, with some tread at one side, that should allow you to operate the switch, push for right turn, pull for left turn, Just think of one similar to the one in your car0030830_column-mount-indicator-switch-black.jpg
    I think that if the switch, would be larger, it would be easier to operate.
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Bossier LoUiSiAna
    Quote Originally Posted by Piratezz View Post
    Jockey shift blinker
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Feb 2022
    New Zealand
    Yep can push it away (right turn) sometimes by moving my hand sideways a little after sort of clamping it from above.
    Just cant pull hook it for a left turn.
    Will the knob pull off? Then I could "operate on it" and refit it. Or make a whole new one.
    Or fit one of those switches you have in the photo i guess.
    Jan 2021
    Descanso, CA
    Exclamation Be careful with that switch
    Isopedella -- I don't have a solution but I do have a warning. The turn signal switch and most other buttons and switches do not directly control the electric current performing the function (the horn button is an exception). Instead they generate CANbus messages sent to the console, etc. If the left-hand assembly is damaged, you're looking at a $400 replacement part.
    I discovered this while investigating converting the horn button into the turn signal cancel function.
    Perhaps a glove maker would have a solution?
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Feb 2022
    New Zealand
    Yep. I agree . I dont like messing with the wires on these type of bikes at all.
    Nothing home made added to my Wing added as well. My Dr650 or Trumpies are a different beast.
    As long as you understand Lord Lucas is The Prince of Darkness. haha.
    Discovered the switch button levers off with a gently applied flat blade screwdriver. There is a post to attach something to. So looking at something along those lines.
    Aug 2020
    Omaha, NE
    Sounds like a project for those 3-D printer folks.
    And that ain't me. Sorry.
    I may be dreaming. But, I hope to get a Spyder or Ryker, soon.
    Just read through "Do-s-and-Do-Nots-for-new-Spyder-owners" and the following posts. Lots of good/helpful info.
    Lots of other forums could go to school on this.
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    keep in mind if you need to cancel your blinker you need to be able to push it straight in towards the bars. Still liked the blinkers on the Harley. One on each side. simple push to operate.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Oct 2021
    Wichita, KS
    I could print something easy peazy. Find someone in your area. They should be able to whip something up for you. Just be sure it is printed out of PETG or better yet, carbon fiber reinforced PETG or PC (polycarbonate).
    Peter Pan has struck again!
    Feb 2022
    New Zealand
    So an update.
    Managed to get hold of Dave who can supply a larger button.
    Few emails, paypal and its on its way along with a gripper paddle shifter pad.
    Arrived today, easy piesie to fit, and makes it much easier to use.
    Hope this can be of help to anyone looking for a larger button and paddle.
    This.
    https://www.spyderlovers.com/forums/...ig-improvement!
    Cheers
    Iso
    Apr 2019
    Florida Swamp
    It is pretty much the same type switch that was on all the Japanese bikes back in the 60s and 70s.
    Don't see any reason why you couldn't add some more meat to it.......... maybe cut something from a block of PVC or other hard plastic. Should hold OK if you glue it to the top of the OEM switch with JB Weld or maybe the 3M super epoxy. I bought a block of insulating material to make a welder connection box from the "Online Metals" website. It is super-hard plastic stuff that does not conduct.
    2019 F3-S , Black & Silver
