Results 1 to 18 of 18
    Jul 2021
    IL
    Default Old Habits die Hard
    I'm approaching one year as a Spyder rider, after 37 years of riding motorcycles. I'm finding that although it only took a very short time to feel comfortable on the 3 wheeler, some old habits die hard. I've ridden the Spyder about 4,000 miles so far, and sometimes still reach of the non-existent clutch lever when slowing down. Occasionally when stepping on the brake pedal, I find myself reaching for a front brake lever that isn't there. And avoiding obstacles in the road is certainly more demanding. I find I can avoid hitting things with my two front wheels, but almost forget about that back wheel in the middle of the bike. Ran over a dead raccoon this morning, but without any problem. My final old habit which shows up at times, is the motorcycle habit of riding in the left third of the lane. I mostly remember to ride in the middle of the lane, but occasionally notice my left wheel getting all too close to the center line. Just some observations at the 9 month mark.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    That's all muscle memory, Vito, I am just glad to hear, that you are aware of it.... , I started my first ride, on the 1st of januari, and had to think, how the starting procedure was again...
    took me 2 or 3 secs, to get it right...
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Apr 2021
    St. Augustine, FL
    I have a similar two wheel background and experiences on three wheels. Road obstacles are a greater challenge to negotiate on three wheels. I still like to ride on the left side of the lane and move to the right side for oncoming traffic when the lane is narrow. A lot of the roads I ride are bumpy in the center of the lane, so straddling the center with a front and rear wheel makes for a more comfortable ride. Muscle memory faded quickly for me. Gaining the reverse gear and losing the kickstand is good!
    2021 Sea to Sky
    Mods: Pedal Commander, RLS Black Ceramic Coated Cat Delete, Passenger Armrests, Driver Backrest, FOBO TPMS, Wolo Bad Boy Air Horn, Foam Handgrips
    Apr 2019
    Florida Swamp
    Yeah, takes a long time to develop new habits that do the job without thinking. When I bought the Spyder, I only switched from a single front wheel Harley trike to the Spyder dual fronts. Had been riding the old home-built Harley Sportster Trike for about 20 years. Reaching for clutch, and brake levers was about the worst habits to break. About 5,000 miles before the Spyder the controls came without any conscious thought.
    2019 F3-S , Black & Silver
    Active Member Woodswoman's Avatar
    Nov 2020
    Upstate NY
    I had a muscle memory moment last year, my first year on a Spyder after 20 years of motorcycling.
    Reached for both clutch lever and front brake lever to slow down during a U-turn. Neither one being there, my brain fuzzed and couldn't remember what to do instead, and unfortunately I rear-ended my husband's F3-T.
    An expensive and embarrassing lesson.
    2016 Spyder F3-S
    Sep 2020
    Middletown, NJ
    More miles will slowly drain most habits. After 19k mi, I still look for exit routes in front of me that only 2 wheels could fit in before I remember I'm riding a parade float!
    2020 RT base , Chalk White
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by RayBJ View Post
    parade float!....Bill
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Active Member sledge's Avatar
    Aug 2021
    Limestone Tn.
    you said everything I would have said.... exactly the same way. and I started in July of 2021 ... so I know your right.
    2011 RTS Spyder
    Linden, CA
    Quote Originally Posted by vito1943 View Post
    Welcome to the club....I have been riding 2 wheels since I was 14 I am now 80 "all most' AND I STILL REACH FOR THE CLUTCH AND BRAKE
    Aug 2008
    MA & NH
    I used to put my feet down when I no longer had to.
    Northern Kalifornia
    Quote Originally Posted by sledge View Post
    I started out on 3 wheels in 2014 and I've done everything that's mentioned above, and I'm still doing it. Geezzzzzz when will it stop?
    Mar 2015
    forrest above Reno, Nv
    And for those of us who still ride 2 wheels occasionally--------- Hope I don't forget to put my feet down at a stop on the old, slow V-Max
    Lew L
    2014 RTS , Circuit Yellow
    Apr 2019
    Clinton, MS
    Vito, the best way I have found to miss something reasonably small with the back tire is to put it under my foot. That's almost the middle between the front and rear tire. Forget who posted this, but it works.
    Active Member shakin_jake's Avatar
    Nov 2011
    north central Fla.
    ~~~ ditto
    Best,
    Jake
    Reddick Fla.
    It’s never too late to have a happy childhood
    2021 Can Am Spyder RT Limited
    2020 Rally , Black
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    I guess riding a shy-prone horse for so many years before 2-wheel, then 3-wheel bikes created a muscle memory I am thankful for. Makes your body “ready” to circumvent quick unexpected moves by the vehicle…like this Spyder RTL..various unseen road anomalies which, at speed, grab the Spyder’s front tire (either one) and try to force the machine either into the ditch or oncoming traffic on a 2-lane unless you muscle to keep it on the path. This is about the only thing I dislike about the 2-up-front vehicle. I never had this happen on my traditional 2-in-back Gold Wing trike. Otherwise.. I like this machine. Additionally, in almost 6000 miles now I am past reaching for the hand-brake but still think they need to include one… Carla
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Your not alone. Riding legal from 1972. Im trying to develop a whole new mindset for the Spyder. In 9 days of ownership I seem to have got no feet down at the stop. Clutch most times. But I really miss the front brake lever. Having to lift the foot and then apply the brake takes longer. But oh boy it works. I regard as a trade off for the quick shifting 6 speed.
    Sep 2017
    INDIANA, USA
    Default It Comes with Time
    ... I know about the Spyder learning curve. But it all comes with Time. For some people it may take a few months. Others may need help with this process.
    I am doing good and enjoying the time and 'wind therapy'.
    My curve was just at 2 months and 1,000 miles. ...
    ENJOY YOUR LIFE WITH A SPYDER
    Very Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    We got our Spyder in the fall of 2017 and now at a little shy of 10K miles. The last big hurdle for transitioning is that I still reach for a front brake lever from time to time. I guess that's not too bad seeing as how I started riding two-wheelers in 1968 and am still riding them a lot more than the Spyder with my total mileage on bikes and the Spyder now at just over 500K miles.
    Those who say " I can't" will always be right.
    2014 RT Limited , pewter (magnesium?)
