Results 1 to 11 of 11
    Active Member Escorial's Avatar
    Jun 2021
    Chicago il
    Default 2020 RTL Is there a way to remove foam grips w/o ruining them?
    My bike came with the large foam grips, I would like to try the bike with out them.
    Is there a way to get them off with out damaging them so I could reuse if I want?
    Aug 2019
    Stoughton, WI
    In my experience, you can easily slide them off. I use gel type hand sanitizer. Now, that said, I also found them not to relax when removed and will be loose upon reinstall. Luckily, they're only about $15/pair. I get the longer ones, as they're generally cheaper and easily cut to length.
    https://www.ebay.com/itm/22488046236...epid=171241426
    Another option are some Grip Buddies. They are removable. I had the Lites version for a Tiger 800. https://www.originalbeemerbuddies.com/home.html
    2022 RT Sea To Sky
    Dec 2013
    A jet of Compressed air directed at the (tiny??) gap between the foam grips & the grips underneath will often help you to remove them....
    That said, the foam grips are the weaker stuff so it's always gonna be a bit of a pain to get them off in one useable piece, & no matter what you do, if they've been there a while, it's often impossible to do anything but damage them beyond future use on removal - which juuust happens to be the easiest & least frustrating way way to get them off, too! Good thing that replacement foam grips are so cheap!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2013
    Marion, Arkansas
    If you need to order other stuff for your Spyder and its over $100.00, you get a free set of foam grips from SpyderPops.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jun 2021
    Chicago il
    Thanks all
    Jul 2014
    Mint Hill, NC
    If I were going to remove my foam grips I would shove a chopstick between the foam and rubber grip and wiggle it around the circumference and then just pull it off. I would not reuse the foam grip(s).
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Ex-Rocket View Post
    This, I have two sets and really like them a lot.
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Start at the inside and roll them off.
    2020 RT Limited
    2020 RT Limited , Petrol Blue
    Oct 2021
    Wichita, KS
    Absolutely the best way to remove any hand grip foam or not.
    Peter Pan has struck again!
    Foam Grips ..... most of the ones I've seen for sale now are .... slip-on .... however the previous owner may have GLUED yours on ..... good luck ..... Mike
    Jun 2021
    Chicago il
    I just ripped them off and tossed them, I did not realise that they were so thin. Much better w/o them, that is me..Thanks
