Results 1 to 10 of 10
    Aug 2018
    north wis
    Default Helmet sound for sled heads
    Going thru posts about sound/comms systems leaves me with questions I know you all can answer! I use a modular sled helmet. I have tried a couple different ear buds and not happy with that. Sled and wind noise makes me have the volume too high. Looks like Cardo would be the way to go but don't really care about the comms part. Do the supplied speakers fit in any helmet? Do any of you use this while snowmobiling? Options I don't know about? Thanks in advance
    2020RTL
    Aug 2008
    MA & NH
    Have never had a set that I was happy with.
    Works for me in all sorts of helmets...
    https://www.ucleardigital.com/motion-series/
    Aug 2019
    Stoughton, WI
    If you want something simple to just bluetooth tunes/take calls, the Cardo Freecom or Sena 5S will work good. I'm very happy with my 5S units. The Sena 5S is around $150, but the unit below is a good deal. What helmet are you using? If it has built in speaker pockets, these should fit easily. One complicating issue could be if you have a visor slide located on your lower left side. I have both a Scorpion EXO-AT950 modular helmet and LS2 Valiant II modular helmet. Sticky clamps work great on these. FYI ...
    https://www.amazon.com/Cardo-FREECOM...7MYCZ2Z7&psc=1
    2022 RT Sea To Sky
    Aug 2018
    north wis
    I have looked at Cardo and U Clear. I use a Gmax modular. Has no speaker cut outs. Can be modded or need to buy or need new helmet with them in?
    2020RTL
    Aug 2019
    Stoughton, WI
    I think instead of carving out some pockets in the Styrofoam, I'd just buy a dedicated modular motorcycle helmet. Can you carve out the Styrofoam for speakers? Sure...
    2022 RT Sea To Sky
    Aug 2018
    Chicago
    BEST IN EVER FOUND
    2015 f3s
    Feb 2020
    CT and ME
    We're using the UClear Motion Infinity sets on both our sled and Spyder helmets. They have really good speakers. The microphones are hidden and the noise reduction is outstanding.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    May 2018
    millsboro,delaware
    Ive had helmet speakers and comm systems on all my helmets since early 80s.Every kind of helmet you can think of except snowmobile and what Ive learned is you can make them fit anything by trimming the foam or rerouting the wires and using all your leftover mounting parts,even velcro or hot glue.One time I made a boom mike out of an old flexible stalk flashlight for a half helmet.I have 2 perfectly good sena 10s models if your interested.
    : 2017 RTL ORBITAL BLUE
    Aug 2018
    north wis
    Thank's all! Think I will try the cardo. If it don't fit reasonably easy I'll get new headgear.
    2020RTL
