Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
  1. #26
    Mar 2019
    NEBRASKA
    Dude....I can send you info on a lil device that I attribute to NorwegianRT....It's a 3d printed device (I paid $14.90 shipped to my house) that goes on the opposite side of the strut to hold up the trunk. It falls into place when lifted then you simply knock it back in ....you'll need a nut and bolt that are laying around in your garage. Norwegian RT sent me the file and I contacted a 3d internet company.
    I got all the info here:
    Trunklid holder RTS.stl
    Dimensions: 0.70 inches x 3.23 inches x 0.39 inches
    Quantity: 1
    Process: FDM
    Material: PLA
    Color: Black
    $14.90
    I can order one for you and have them send it to your house
    2012 RTL 14 RTS , Pearl White @ Pearl White
  2. #27
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Bangorbob View Post
    I found the strut/shock or whatever it is called. It is not strong enough to hold the lid open. Anyone found a stronger strut that I don't have to take 2nd mortgage to buy?
    This is for my 2020 RT limited.
    Go to McMaster Carr website and do a search there. They have all different kinds and are reasonable and shipping is very fast.
  3. #28
    Oct 2021
    Wichita, KS
    Quote Originally Posted by davev1pa View Post
    Quantity: 1
    Process: FDM
    Material: PLA
    Color: Black
    $14.90
    Won't work on a 2020+.
    Peter Pan has struck again!
  4. #29
    Nov 2018
    Des Moines IA
    Replacing the gas strut is pretty easy on the 2020. Takes about 10 minutes. You remove the two screws inside the trunk that hold the backrest on. (Circled in red) The backrest lifts straight up. Once you get that off, the strut is easy to get to. You have to remove the bottom 1st then the lid will swing up high enough to get to the upper bolt. I am going to try adding a spring that fits over the strut.
    2020 Spyder RTL - Blue
    2018 Spyder ST Limited , Asphalt Gray
