Results 1 to 9 of 9
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default User map - any info on another map site?
    I have tried for several months to install the SpyderLover User Map with no luck.
    Does anyone have information for another user map site? Thanks All
    2022 F3 Limited , Monolith Black / Dark
    Sep 2017
    INDIANA, USA
    Default User Map
    What happens when you try to install the 'User Map'.
    ENJOY YOUR LIFE WITH A SPYDER
    Sep 2020
    Middletown, NJ
    If you mean the map of member locations, it hasn't worked since I joined a 1 1/2 years ago.
    It used to display the map but we couldn't add new locations. Now the map isn't displaying at all.
    2020 RT base , Chalk White
    Feb 2021
    Indiana
    I can't get user map to work
    Oct 2016
    Faribault, MN
    Cirhere, See Below
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Oct 2016
    Faribault, MN
    Cirhere, do you have a popup or advertising blocker enabled? That could cause the User Map (at https://www.spyderlovers.com/forums/locations.php ) to not display properly. It works on my system as intended.
    FYI there are two different maps available here on Spyderlovers:
    the SpyderLover User Map - https://www.spyderlovers.com/forums/locations.php which lets folks see where other Spyderlovers indicated in their profile settings where they live; and
    the Visited States Map - https://www.spyderlovers.com/forums/maps.php where you can make a map for your signature block of the states you've ridden your Spyder to/in.
    Both are linked at the top if each thread in the horizontal menus. Here's my listing on the USER map when zoomed into my hometown.
    Last edited by Peter Aawen; 11-02-2022 at 06:01 PM. Reason: Exposed hidden URL's iaw Forum Policy
    Safe Rides,
    IBA 70020
    Northern Kalifornia
    Quote Originally Posted by RayBJ View Post
    Yep, me too, useless. I just tried to mark my location with info on how I can help a fellow stranded spyder lover. It doesn't work for me either.
    Jul 2016
    Murfreesboro, tn
    I've created the signature with USA and Canada but cannot see how to link to posts or replies.
    Let me know.... It seems to show now....
    Thanks..
    Oct 2016
    Faribault, MN
    Quote Originally Posted by tntherapy View Post
    Thanks..
    So that's the visited States map, this thread is really about the USER Map.
    Safe Rides,
    IBA 70020
