Results 1 to 25 of 43
    Jun 2021
    OR
    Default Remote Garage Door Opener
    I was browsing Lamonster I believe and saw they had a garage door opener for the bike. I thought that was a good idea but they were always out of stock every time I looked. So I decided to make one myself. Found a water proof momentary switch that matches my Spyder switches. Got an extra remote for my garage door opener. I also got a dc to dc converter to convert the 12 volts to 3 volts so I did noy have to replace the battery and the remote would only work with the key on but decided against using it for now since I placed it where I can get to it easy.
    So this is what I did.
    1. Program the new remote to the garage door.
    2. Opened the remote and soldered a wire pair across the switch that was programmed to open the door.
    3. Sealed the remote case with silicone to prevent water getting in.
    4. Used Velcro and mounted the remote under the switch console where it should remain dry.
    5. Removed the blank from the switch panel.
    6. Feed the wire to the new switch and snapped the switch in to place.
    2021 Spyder RT Limited
    Oct 2015
    Lynden, WA
    Great DIY...Looks very OEM.
    I did the same but put the push button on the left side panel.
    Where did you get the DC to DC Step down?
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    I just put my OEM opener in the glove box .... KISS .... but you did a nice job ..... Mike
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Agree with just put a remote opener in the glove box. Mine is the aftermarket "2 door" opener type (I think Chamberlin brand) bought at home depot.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Jun 2021
    OR
    I got the DC to DC converter from Amazon.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jun 2021
    OR
    I have enough stuff in my glove box and is why I opted for this.
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    Quote Originally Posted by teninospyder View Post
    Same here. I have 2 remotes. 1 for the Spyder, the other for the vehicle. Although, I have mine attached, with velcro, on my Spyder dash. Perfect, and easy access!
    2014 RTS Pearl White
    2014 RTS , Pearl White
    Feb 2019
    Portland, Oregon
    My solution...easy and free. I place the remote and spare key in a jacket pocket, so I am able open/close the garage door from the bike. I also have a spare key handy if I should lose the active one. The small key is for the Lid Locks.
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Just what I did, Mike No work involved, and no problem either
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Quote Originally Posted by redrazor View Post
    Thanks, ... some have said they have NO room for it .... I have an RT so the glovebox is a bit larger ... In my glove box I always have my XM receiver, a pack of cigs , a lighter, .... I small bottle of Fuel conditioner .... a pencil, matches, air pressure device .... my garage door opener ..... and a little extra space ..... Mike
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by Haze View Post
    I did the same thing years ago. Tiny, momentary button on the left dash. NO fumbling around for a remote. Cost pennies. For a garage kept -- this is a must. Would you not have an easy to reach garage door switch/button for your CAR????
    Lew L
    2014 RTS , Circuit Yellow
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    On my F3, I use 3M Dual Lock (a "super" velcro type fastener) to fasten my remote. Somewhat easily removed when I get off and walk away from the Spyder.
    Feb 2022
    New Zealand
    Quote Originally Posted by shardt View Post
    Yep. Good bit of work there.
    I have a couple of rides so I pop the remotes in the glove box or jacket pocket.
    Apr 2022
    GA
    How cool would it be to wire it in to the PTT switch!
    2017 SPYDER RT LIMITED
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by Isopedella View Post
    I do much the same, except that I attached my remote with velcro tape to the inside of my glovebox. Just pop the lid to my glovebox and press the button. Wound up costing me maybe 10 cents and works like a charm.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Oct 2021
    Wichita, KS
    Hey shardt how did you get that dummy blank out of the switch plate without removing the plate? Or did you remove the side panel to remove the plate to get to it?
    Peter Pan has struck again!
    Dec 2020
    Hartwell, Ga
    Just remove the side panel and reach in there to release it. No problem unless you have fat hands/arms.
    Jun 2021
    OR
    I used a small screwdriver. There are tabs on the top and bottom of the blank. Use the screwdriver and slide it under the blank on the bottom and pry up. It will pop out easy.
    Oct 2021
    Wichita, KS
    Thanks for the replies guys. I actually had the job done before I got your reply shardt. K80 you saved me a bunch of time. I was prepared to pull the long back panel and front panel thinking I would have to pull up the entire console. I didn't realize you could pop the blank out while the console was still installed in position. It only took about 15 minutes to install my new Mo-Door garage door opener (which costs way more than it should) but looks and works great! I am one happy camper tonight. I appreciate the write-up which helped a bunch!
    Feb 2021
    AZ
    where did you find the water proof momentary switch that matches Spyder switches ?
    Mar 2021
    Arizona high country
    I got a universal remote and used velcro to mount by gas filler. Top left button opens the gate at the end of our driveway and the top right opens the shop door where the Spyder gets parked. Still leaves me with a couple of more buttons that I can use in the future for something.
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Studeblu View Post
    Not sure what you have for a ride, but most kits come with the switch. Did you check out our vendors?
    Oct 2021
    Wichita, KS
    My switch came with my Mo-Door kit I bought from SlingMods. I highly doubt it is water proof.
    Danbury Connecticut
    Very nice. I did something similar on mine. The only difference is my CDO (that's OCD with the letters in correct alphabetic order) forced me to use an OEM switch. I used a windshield switch to get the momentary contact and colored in the windshield graphic. That way it has the arrows on it and it's also lit at night. I won't bother you with photos unless someone asks.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Oct 2021
    Wichita, KS
    Awesome idea! Very nice.
