Your thoughts on using the hitch as a tie down??
Thoughts on using trailer hitch on RT for straps just to keep rear from moving instead of strapping thru wheel, thanks, heading to florida in a week.
I would not trust the hitch on a Spyder for a tie point. Best is to strap around the wheels, like the car haulers.
The hitch is directly attached to the axle and using it to tight down the bike would be the same as tying down the tire, I would use it!!!
I would definitely use the hitch. It is very sturdy and makes a great tie-down point.
If the hitch isn't a safe tie down point, it sure isn't safe for pulling a trailer.!!
I use a soft tie around the passenger floorboards, then of course add regular tie downs. They are sturdy and pull it down and forward into the chocks.
That's how I always tie the rear of mine down...I have two stainless steel Clevis's I attach to the safety chain eyes on the hitch and run my 2" strap thru them...larryd
