Rear Chrome Wheel
Searching for a rear chrome wheel for a 2012 can am spyder RT part number 219400574.
Believe 2012 is the14 inch diameter. The next yr (2013) went to 15’s & Brembo brakes. (Hopefully helps the search)
Reason: 2012/13 ;-)
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
I thought the rear wheel has always been a 15 inch. Its only the front tires were 14 inch in the beginning up to 2013.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
BaJa Ron Ultra 3 pcs sway bar kit
7jurock 25" tinted windscreen w/flip
Frogman Dave's "Signal Button"
If in Doubt, Don't Do It!
" Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
You are correct in the sizing that's why I indicated the part number in my original post as 219400574. The newer wheel for the 2013 and up part number is 219400575 but definitely wanting chrome oem for 2012.
God love you for wanting a chrome rim in the rear!!! I have a hard of enough time keeping my front rims clean, I wouldn't want to clean a rear rim like that!!
Check out Ebay. Currently, there are 3 rims ( used of course ) of what you are looking for. I recently purchased a used rear Chrome Rim from an individual that was parting a Spyder out. Going to make my rear tire changes that much easier come replacement time. Best of luck in your search. I attached a couple of links below for you.
https://www.ebay.com/itm/33375227144...wAAOSwXmRfhN06
https://www.ebay.com/itm/17471786504...oAAOSwv0NgaHtD
2014 RTS Pearl White
Boy, I'm getting a lot of info except the real answer I'm looking for, LOL. I've got a rear chrome wheel on my spyder and super easy to clean if you have a floor jack and no problem bending down. Just use a floor jack and lift the spyder at the rear shock mount just enough to raise the rear tire, chock the front wheel, release the brake, put bike in neutral, tire will rotate freely. Use window spray cleaner while spinning wheel by hand and wipe clean. check that air pressure while down there, doesn't take long at all. Clean that wheel my peeps. Yeah I know, seems anal but different strokes for different folks. HOLLA.. PS: works on black wheels too!!! Now, what about that elusive wheel part number 219400574?
https://www.brppac.com/brp-219400574.html
Originally Posted by Briorick
https://www.brppac.com/brp-219400575.html
Looking at both part numbers it appears that the newer one piece wheel/hub has replaced the two piece unit for the earlier models.
"Stupid is as Stupid does"
Don't Drink and Drive or Ryde!
Each Day is a Gift
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
