Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    May 2014
    Benson, NY
    I got this one from ebay for under $20. w/ free shipping. It's made by pit posse.s-l1600.jpg
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
  2. #27
    Feb 2020
    CT and ME
    I have 2 twelve point sockets. I've had the rear wheel off/on and axle loosened a few times for tire change and belt adjustments. No sign of the nut getting rounded.
    I will add that for $125 for the tire change I would now pay that rather than doing it myself!
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
  3. #28
    Active Member thereverend's Avatar
    West Monroe, LA
    i HAD TO PAY $125.00 FOR REMOVAL AND $125.00 TO REINSTALL. i WILL BE DOING THE NEXT ONE.
  4. #29
    Quote Originally Posted by spyder01 View Post
    That would probably work but would take up too much space. I was thinking of the kind of airbag that you put inside of a coil spring on trucks, it will collapse down to nothing and weighs nothing, and I always carry a tiny compressor.
    I had those ( air bags ) for my toyo pk-up .... they were not small, nor were they collapsible. Also, unless encased inside something, they weren't stable for lifting anything..... Good luck .... Mike
  5. #30
    Active Member bayoumanPIBE's Avatar
    Columbia, MO USA
    I just picked up a 36mm 12pt from Menards
    https://www.menards.com/main/tools/h...8245253&ipos=1.
    It doesn't bite on tight and is loose as if it will strip...is this normal? I say not, but Spyders have surprised me many-a-times.
    FYI. I have a 2021 F3 Ltd if it makes a difference on the year...
    Reiterate and add Questions
    1. Should the 36mm 12 point wrench be loose? I know we all have diff definitions of loose...just too much play.
    2. Should there be a cotter pin on the right hand side / brake side of the rear axle nut?
    3. Are ya'll testing belt tension while it's cold or hot?
    Life's short...Play it by ear and ryde!
  6. #31
    Quote Originally Posted by bayoumanPIBE View Post
    I just picked up a 36mm 12pt from Menards. It doesn't bite on tight and is loose as if it will strip...is this normal? I say not, but Spyders have surprised me many-a-times.
    Do you have a pair of calipers you can measure the opening? If so, to my way of thinking the opening shouldn't be more than maybe 36.1 or 36.2 mm. I just checked my two 36 mm sockets. They are about 36.1 to 36.2 mm across the flats. Even my no-name HD/VW 36 mm axle nut wrench such as the one shown in an earlier post is about 36.2 across the flats. I bought a set of Harbor Freight crow foot wrenches about a year ago. The one I needed to use, 18 mm, was a loose fit. When compared to my 30+ year old Craftsman 18 mm open end wrench the opening was quite a bit bigger. I returned the set.
    If the wrench you bought was economy priced with an oddball name, or the name of a line of cheap tools, then yes, it probably is much looser than it should be. Sometimes you really do get what you pay for!!!!!!!
  7. #32
    Columbia, MO USA
    I unfortunately do not have anything to measure... I do agree about what you get for the price we're willing to pay. The wrench is by a company I have not heard of (Masterforce), but that does not mean it's good or bad...might be a Menards brand. Pending life...I might go find another wrench (or the like) or order one a few others showed they purchased and used. I was hoping to test again this "since day-1 non-stop shaking" issue while it's not snowing. Maybe the nuts are stripped from the dealerships all messing with it...will check asap.
  8. #33
    Feb 2020
    Minnesota,USA
    I don't believe you will have any problem with those sockets. Just don't use an impact wench on them!...Bill ...
    If in Doubt, Don't Do It!
  9. #34
    Aug 2020
    Georgia
    I don't know about a 12 pt socket but mine is a 6 pt and it worked great. I would be hesitant to put 166 ft-lbs of torque on that socket of yours if it is not snug - you might have a bigger headache if the nut corners get rounded.
    There was no cotter pin on my 2020 RT although it looked like there should have been one. But I now have 10K miles so far and it is holding tight so I guess no need for it.
    When I changed the OEM Kenda at 4K miles, I didn't touch the pulley-side axle adjuster when I changed it so I didn't think it necessary to check the tension at that time. I will check it on the next change though. Doesn't hurt to check it. You can buy one of those Cricket tools for around $15 from Amazon. Don't ask me how to use one cuz I haven't used mine yet.
    BTW, a shallow socket worked best for me. It gave me a little extra room to get the torque wrench in there between the muffler and the swingarm. There is a cable that got in the way too - can't remember but seems like it was the emergency brake cable.
    Sold: 2020RT base with numerous improvements and farkles
    Previous 2 wheels: 3 BMWs, 1 Honda, 1 Yamaha and 1 Husqvarna
  10. #35
    Feb 2019
    Portland, Oregon
    WILCO.......Buy a Krikit II - you will be doing readings in the 150 +/- 10 range, so get one that reads no more than 200. They come with directions for use and it's very simple. You just have to be careful not to touch it on anything as you are withdrawing it. That'll need some practice.
    When you have it, get on the floor and take readings half way between the pulleys. Take a few, so you know that they are correct. Rear wheel on the floor is 150 to 160. Off the floor is 140. Factory spec has is too tight and produces belt vibration. I now have none - no add on tensioner needed. And the bearings have an easier life too.
    I wouldn't wait until the next change, check the belt more frequently.
  11. #36
    It's been a long time since I replaced the tire so it's about time to check mine. But I'm reluctant to do it because I might find I should change the belt tension and I've had such a devil of a time setting it and keeping the belt aligned I don't really want to touch it!
  12. #37
    Feb 2019
    Portland, Oregon
    Someone recently posted a way of thinking that simplifies the job. The left adjuster is for belt tension, the right for alignment.
    Apply some anti seize on the working surface of the bolt head and nut and they won't crawl.
  13. #38
    Makes sense. However, even grease on both sides of the washer under the nut didn't keep it from crawling! The big problem is, and it's been mentioned before on here, is the lack of an adjuster that will keep the axle from moving rearward. I don't remember now but I may have finally resorted to torquing the bolt head while keeping the nut fixed. Studies I came across indicate it doesn't matter much at all which end of the bolt is torqued.
    Last edited by IdahoMtnSpyder; 03-01-2022 at 01:49 AM. Reason: corrected forward to rearward
  14. #39
    Clinton, MS
    That is how I have found to make the simplest belt adjustments.
  15. #40
    Feb 2019
    Portland, Oregon
    Makes sense. However, even grease on both sides of the washer under the nut didn't keep it from crawling! The big problem is, and it's been mentioned before on here, is the lack of an adjuster that will keep the axle from moving forward. I don't remember now but I may have finally resorted to torquing the bolt head while keeping the nut fixed. Studies I came across indicate it doesn't matter much at all which end of the bolt is torqued.
    Maybe your bike is different, but when I'm adjusting the belt, I have someone press their feet hard against the back of the tire to pressure the wheel forward. Works for me.
  16. #41
    Feb 2012
    Spring City,Utah
    I have found that if I use a ratchet type tie down strung from the rear tire to a footpeg I can put enough pressure to keep the wheel from moving while torquing the nut.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  17. #42
    You're right. I got it bass ackwards! Just remembered how the adjusters work. I was trying to figure out why, if the axle wants to move forward, I put a wedge shaped block between the tire and swingarm on the brake side to keep it from moving.
  18. #43
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    He needs a 36mil open box end wrench and cut it hslf
