Results 1 to 5 of 5
    Apr 2016
    Grass Lake MI.
    Default Does the 2021 RTL have 1or 2 oil drain plugs?
    I have a 2021 RT Limited. I am about to do the first oil change. My 2014 RTS had two (2) drain plugs. I am putting in magnetic plug (s) in with the oil change. I can only find a single magnetic plug for the 2021 online. My question is does the 2021 RTL have one or two oil drain plugs?
    2021 RT Limited , Marsala Red
    Feb 2020
    Minnesota,USA
    Lamonster sells the Gold Plugs required. Two different plugs with a hex head for less chance of stripping them out.
    Give him a shout!.....Good luck....Bill
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Sep 2017
    INDIANA, USA
    Default Drain Plugs
    .....Well, as far as I know, there are still Two Plugs for draining the engine oil.
    I have not heard anything about a change.
    Hopefully someone will come on board and post up.
    I would have thought Lamonster's Garage would have been able to tell you.
    Just a thought my friend. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Oct 2020
    Vinton, IA
    They are on LaMonster's website currently, and VERY reasonable dollar-wise. Search for "magnetic drain plugs", rather than by year & model; should get you right to them.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Jul 2014
    Mint Hill, NC
    Why not simply go to your operator's guide, read pg. 103-106 and learn exactly how to do it, including the number of drain plugs you must remove?
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
