Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    The tool MSRP is $68.99 but you probably can't find one! I would try using a Channellock pliers. Just drop the jaws into the notches.
    Or you could try a few gentle taps with a a softish drift to loosen it enough to get it out; and a few taps the other way to tighten it up enough after putting it back in. . But I'd suggest NOT using a cold chisel like that!
  2. #27
    Clinton, MS
    If it only needs 15 ft/lbs torque a large set of needle nose pliers would probably work.
  3. #28
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    The great feeling you get by being able to refer to a service manual is second only to that from the activity you enjoy with a woman! Go to www.canammanuals.com.
    No tool is mentioned in the 2014 manual, but it is shown in the 2013 manual! This is just one example of many inconsistencies that exist in BRP's documentations, within a specific document and between successive years of documents.
    Idaho, Thanks for the diagrams, and the canam manual link. Made sure I saved them all for future reference.
    I did see on ebay there was such a tool listed, but I think for the price I will use my own ingenuity and invent one. Your channel lock suggestion sounds like it would work as well. I was thinking a piece of cross steel inserted across the slots and a Crescent Wrench. Seeing the nut is torqued so low it wouldn't take much effort to remove and reinstall it.
    Glad to see the ingenuity of creative ideas being mentioned here. It's amazing what we can accomplish and invent when we want to save some bucks for ourselves! Along with your diagrams, those diagrams helped many of us, I'm sure.
    Thanks again.
    2014 RTS Pearl White
    2014 RTS , Pearl White
  4. #29
    Apr 2021
    Southern IL
    Quote Originally Posted by JSRT View Post
    I made a wrench for that nut the last time I had a wheel apart. I just used a piece of 1/4 plate steel - cut to fit into opposite grooves, welded to a piece of 1/2 square bar. The bar is maybe 8” long so a gentle snug won’t apply too much torque. Here’s a couple photos:
    Great idea! This is something similar to Spyder Stuff's invention he made in his video ( @ approx 4:32 ) with the exception he welded a Bolt onto his steel piece to be able to use a ratchet. Such ingenuity!
    https://www.youtube.com/watch?v=juVK1ogc1BA&t=306s
    Both great ideas.
  5. #30
    Bossier LoUiSiAna
    & another when mine failed suspect from impact with large Road patch. More details in thread, definitely keeping some spare in hand considering parts delays as of recent.
    https://www.spyderlovers.com/forums/...UESS-this-part
  6. #31
    Apr 2021
    Southern IL
    Good Afternoon everyone. Just wanted to take a moment and Thank everyone for their contributions, input, and participation with my quest to find the answer to this Funky Nut.
    Your input was invaluable , and we actually found out what, and how, to tackle ( with a little ingenuity ) this culprit should any of us need to.
    Once again......... Thank You, All. Great Work!
  7. #32
    Quote Originally Posted by Briorick View Post
    Good Afternoon everyone. Just wanted to take a moment and Thank everyone for their input and participation with my quest to find the answer to this Funky Nut.
    You're welcome!
  8. #33
    Dec 2009
    West Oz
    ebay item 121077395218 is the castellated socket that fits that nut perfectly.
  9. #34
    Feb 2019
    Portland, Oregon
    In situation like this, I have used a piece of steel flatstock cut to fit and applied a large Crescent Wrench for twisting. Cheap and easy - that's me.
  10. #35
    Apr 2021
    Southern IL
    Another "Cheap and Easy" here as well . That's exactly the method I was thinking myself. Keep it simple!
  11. #36
    INDIANA, USA
    Default Diy tools
    I am glad to hear that you got the job done. Thank You for your Updates. .... : )
    ENJOY YOUR LIFE WITH A SPYDER
