Results 1 to 25 of 30
    Nov 2016
    Upstate NY
    Default DIY Car tire mounting
    I hand mount tires for my Car, truck and Spyder. I use a manual tire mount that is available from Harbor Freight and Tractor Supply. I also use the No-Mar tire bar(best tool I own!). I also have a set of spoons that are sometimes necessary. Tires for cars and trucks are very easy. The rear tire on my Spyders are reasonably easy. The front tires on the Spyder are very difficult and definitely not for beginners. They require the use of spoons to mount and lots of muscle and care not to scratch the wheels. Tape around the wheel will help prevent damage. The No-Mar Tire Bar wont mount the front car tires for the Spyder.
    I also maually balance my wheels using a balance rod and cones from No-Mar and my own homemade balance stand. It works very very well and is very sensitive. I can static balance to within 1/4 ounce. Has always worked well on my cars and trucks, and only limited experience with the spyder, but so far, good results.
    If you like to do stuff yourself, you should check out the Tire Bar and balance products from No-Mar. At least watch some of the videos on youtube. It really does work as easy as the videos show. It wasn't super cheap, but it was worth the cost. Hope this helps out some of you guys who like to do the work yourself. Here is one video I found with the same setup I have:
    Dec 2015
    Oakley Utah
    That is awesome! Thanks. I may just try that setup.
    Is anything special needed for Spyder rear wheel?
    Why are the front tires so much more difficult?
    2014 RTL Platinum
    Nov 2016
    Upstate NY
    When installing car tires on the front wheels, the car tires seem to have a larger bead? If thats the best way to describe it. I mounted 2 Federal Formozas tonight and it was a tremendous struggle. I remember the tire shop also struggled mounting car tires to the spyder wheels on my 2014. I had to fight with them tonight and actually put a small scratch in one wheel that I had to repair. Had to use spoons. no room for the tire bar. For the rear tire, I used the motorcycle wheel clamp on the tire changer. It clamps to the outside of the rim to hold it so I can dismount the tire. Its available from harbor freight also. https://www.harborfreight.com/motorc...ent-60810.html I did bend the grip tabs a little so it grabs the rim better. You can glue some rubber on the tabs for better grip also.
    Active Member wyo85's Avatar
    Aug 2021
    Wyoming
    This is what I got on Amazon to change trailer tires and my motorcycle tires, hope it works good on my Spyder too. Also use a cheap tire changer from Harbor Freight .
    https://www.amazon.com/dp/B00LC4MLPK...v_ov_lig_dp_it
    Quote Originally Posted by Joel The Biker View Post
    I don't think " bead size " has anything to do with it ..... The BEAD on the tire and corresponding LIP configuration on the wheel are FED- D.O./T. Regulated .... and they MUST MATCH ..... it's more likely the narrow width of the tire you are using .... JMHO ....Mike
    Feb 2020
    Minnesota,USA
    I change my own tires. The rear rim is wider which makes it a little easier to mount a New Stiffer Sidewall car tire. Note: (I remove the rotor & drive sprocket)
    The front rims being narrower, and trying to protect the outer face of the rim makes it a bit more miserable to work with the New Stiffer Bead and Sidewall. The old Kenda tires are made from used condoms, softer and short on Viagra.
    I use a bead breaker, Black Widow BW-2065; and (3) Stens tire tools 750-644, 16" length. All came from Amazon. Use plenty of Lube & Patience!
    IT is a JOB, (at least my Kumho tires were) , Front worse than the Back! Good Luck........Bill
    If in Doubt, Don't Do It!
    SoFlo
    I also have done tires on our and friends Spyders. Yes, both front and rears are done by hand. For balancing, the rears are static balance checked, the fronts I use my spin balancer and balance within 0.1 ounce dynamically to prevent precession and wobbles felt in the handlebars.
    Actually, I have fixed a few Spyder vibration issues the dealers gave upon and stated were normal.
    Regardless, changing tires is not my idea of having fun.
    Nov 2016
    Upstate NY
    Here is my homemade balance stand. Just mounted these car tires on a set of scratch-n-dent spyder wheels I got on ebay.
    Dec 2015
    Oakley Utah
    Nice balance stand, Joel.
    2014 RTL Platinum
    Nov 2016
    Upstate NY
    Thanks. The largest wheels I have balanced on it so far are 19" with 245/40R19 General Altimax RT43 tires for my Honda Accord. They ride smooth as glass. It is made from aluminum from Lowes that is simply bolted together. The bearings are from Amazon.
    Jul 2010
    Las Vegas, NV
    I have the No Mar complete set up. No trouble with front or rear Spyder tires. I’m sure we have done over 100 sets. Easy to do, and have their wheel balancer, too. Great company, great product.
    Joe Meyer
    Dec 2015
    Oakley Utah
    Quote Originally Posted by cptjam View Post
    Hmmm....I seem to remember this strong ox of a guy using that rig to do my back tire! Maybe I need a hydraulic / pneumatic rig!
    2014 RTL Platinum
    Nov 2016
    Upstate NY
    Or you could make one of these. Im going to try it.
    May 2014
    Benson, NY
    Default HF tire changer
    Here's an easy mod to the original mount bar that comes with the HF tire changer. It doesn't bugger up the rims and makes dismounting the fronts as easy as peeling a banana.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Bensonoid View Post
    What is it?
    2014 RTL Platinum
    May 2014
    Benson, NY
    What is it?
    The pictures are of a mount dismount bar that comes with the HF tire changer. If you have one you can see what I did to make it work without scratching your wheels. The dismount end is a replacement No-mar tip and the mount end has a piece of laundry detergent jug zip tied to it. It only makes sense to someone that has the HF tire changer that the OP was referring to.
    Sena 20s
    Dec 2015
    Oakley Utah
    I understand now. Thanks
    2014 RTL Platinum
    Nov 2016
    Upstate NY
    Looks good Gary. How did you attach the Mo-Mar black tip?
    May 2014
    Benson, NY
    The tip fit inside black iron pipe (I think it was 3/4 inch) ,then that fit in the mount/dismount bar. I used a roll pin to hold the tip.
    Sena 20s
    Aug 2021
    Wyoming
    I mounted some tubing on my HF tire changer to slide into the hitch on the back of my truck so I didn't have to permanently mount it on my garage floor . It likes to twist a little because it about 4 feet back from the truck but works good. I guess I could put straps on the changers feet and then to the truck would fix the twisting but its not to bad.
    May 2014
    Benson, NY
    I installed red head drop in anchors in my floor so I can bolt in the tire changer as needed and when I remove it nothing sticks up from the floor. I like the hitch idea, you can "take it on the road".
    Sena 20s
    Apr 2022
    GA
    I used balancing beads in my huge RV tires. Are these commonly used in motorcycle tires?
    Nov 2016
    Upstate NY
    No. I have tried them without success.
    Sep 2016
    N.E. Ohio
    I am fortunate to have an AMI certified mechanic as a neighbor. Whenever I need tires mounted, or anything else for that matter, he's my go to guy. We always barter for each other's services.
    Dec 2022
    NY
    I love Dyna Beads. I buy them in a 20 lb tub. They come with a chart to tell you how much to put in a tire according to its size. Most car tires require 3½ to 4 ounces per tire. It’s far easier to dump them in before you set the bead, although it is possible to put them in through the valve stem on an already mounted tire.
    https://youtu.be/eq263AYgyYg
    Quote Originally Posted by dmiles View Post
    They’re awesome on bike tires!
    Last edited by Peter Aawen; 01-16-2023 at 05:27 PM. Reason: duplicating the thread archeology.... ;-)
    ~~2010 RS SE5 My first Spidey, but not my first ride~~
    The trigger’s been pulled. We have to
    get there before the hammer falls.
