Results 1 to 24 of 24
    RT-S SE PE#0192
    Sep 2007
    Topeka, KS
    Default Looking for gently used RT SE6. What year?
    Sold my Harley.. My hands don't work so well anymore so I'm looking for a Spyder.. What year between 2015 and 2019 would you recommend? Price is main consideration.
    Dwight
    2014 was the year of the DESS problems.
    If price is the big consideration....2015 would be your year. RT's from then on are not on anyone's "don't buy" list that I know of.
    Feb 2012
    Spring City,Utah
    I would suggest you find the newest 1330 with the lowest miles in your price range. You can go back as far 2014. Do you know enough about Spyders to know which model you want? There are basic F3 models with low miles in the 12-14000 price range. I think the F3 started in 2015. Good luck on your search, be patient, haunt your local "for sale" sites, tell all your friends what you are looking for. Do you have any used bike stores in your area, tell them what you want?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2015
    Chilliwack, BC. Canada
    Mine is NOT for sale, but I’ve owned it now for 6 1/2 years, have just under 60,000 kms on it and have NEVER experienced the DESS problem, soooo I don’t think that you should lump all 2014’s having a DESS problem. I know that there were a few that had the problem, but I’d guess the more of them did not. jmho
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Yes 14 had that issue and 15 also ..... however it was an easy and in-expensive DIY repair ( $140.00 for the new module ) ..... In 2018 BRP switched to a different instrument panel along with the Audio .... And this did not make it better IMHO ..... I wouldn't buy any Spyder from 18 and up. ... Improving the sound ( quality & volume ) was easy () ON 14-17 models ) using after-market speakers and keeping the stock radio .... good luck .... Mike
    Dec 2015
    Oakley Utah
    Quote Originally Posted by bigbadbrucie View Post
    2014 RTL Platinum
    Mar 2015
    Fritch, Tx
    If we didn't already have our 2014 RT, I would be all over this deal on a pearl white RT in central Texas.
    Those who say " I can't" will always be right.
    Aug 2018
    Columbus
    Quote Originally Posted by cruisinTX View Post
    I was going to link this one as well but there are a few on the for sale subforum.
    Jan 2021
    Descanso, CA
    on DanY 2016 Spyder RTL. No accessories needed except a rider!
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Here is one priced right if you don't mind the miles. https://www.spyderlovers.com/forums/...-Spyder-RT-Ltd
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Oct 2021
    Wichita, KS
    I feel exactly the opposite. I wouldn't buy anything older than an '18 because of the digital dash. In fact I wouldn't buy anything older than a '20 because of the full led light package. Different strokes for different folks.
    Peter Pan has struck again!
    Dec 2015
    Oakley Utah
    Quote Originally Posted by FrogmanDave View Post
    OP specified '15 to '19.
    2014 RTL Platinum
    INDIANA, USA
    Default Spyder
    2015, 2016 or 2017? Well I enjoy my 2016 RT LIMITED.
    This was my first Spyder and I purchased it 11/2016.
    I had enjoy riding on 2 wheels and finally needed to change over to the Spyder.
    My choice for you would be a 2016 RT/RTL. .....
    Look at your budget and make sure you get what is best for you. Take some time and do your homework. ...... : )
    ENJOY YOUR LIFE WITH A SPYDER
    Jan 2021
    Descanso, CA
    Exclamation Talk to Willie
    Dwight -- more information on Willie's Spyder at CycleTrader https://www.cycletrader.com/listing/...SE6-5019282524
    Here's my experience: I purchased a 2014 RT-S SE6 with 77K miles and RT-622 trailer in San Diego, CA for $9K. Because I was the 3rd owner and the 2nd owner seemed to be a pass-through only, I didn't have a service history. So I established a maintenance baseline for everything. I could afford to do this because I had a workshop, tools, skills and dexterity.
    The 1330cc Rotax engine is a sweetie; the 6-speed transmission shifts are usually smooth now that I'm using Motul 7100 15W-50; and the cornering was treacherous until I replaced the tires then was concerning until I replaced the shocks although I still have to repair the air suspension. Now at 85K miles it's the freeway runner I wanted and more importantly needed.
    My only "lifetime" concern is the clutch wear because apparently the 1st owner took long 2-up rides with the trailer in the Southwest. When I changed the oil (I did it three times before reaching happiness with Motul) it was black although no sparklies in the drain pan or jaggies on the magnetic drain plugs. I'm not getting any slippage but I've studied the service manual and I think I can replace the clutch plates without removing the engine from the chassis.
    The point of my story is talk to Willie. I expect his Spyder received TLC over it's 106K miles and you can ask him yourself, something not available to me. I also expect that like me, your worst-case "remediation" issues will be the air suspension and the clutch. Willie's price leaves you plenty of headroom for both, especially if you and a friend can perform the work.
    PS Grip Puppies and Show Chrome handlebar weights will keep your hands happier!
    with your last sentence .... I fixed ALL my speaker sound issues for very little money and labor .... I looooooooooooooooooove my RT radio ... now ..... Mike
    INDIANA, USA
    Default Spyder or Ryker???
    Just wanted you to have a second option.
    Check out the Ryker for a possibility.
    They are good for the first time 3 wheelers.
    You can get a used or a new Ryker, what ever you like.
    People on this Forum have done this route.
    First a Ryker and then traded for a Spyder.
    Again do what you can afford. ....
    May 2013
    Apex, N.C.
    If you are looking for a more touring related spyder, I would go with anything from 2014 RT up. Right now there are 2 great deals in my area for under $14k. One is a 2015 and the other is a 2014. Anything older that 2 years old will probably not have a warranty, unless they purchased an extended warranty. For that reason, I would look to the standard dash (2014-17) and not the digital. If you go up in year, I would look into getting one that might still have some extended warranty. Good Luck.
    Dec 2020
    Hartwell, Ga
    Lamonster has a facebook group where there is a nice RTL listed recently. 2017 with a ultimate seat.
    Just scroll down a few post's.
    https://www.facebook.com/groups/187899911784385
    western Colorado
    I have a 15 RTS with low miles that I’m trying to sell
    Mar 2015
    Fritch, Tx
    I just went to that FB; it looks like you will have to join to participate in any discussion. Pictures are viewable, however.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by happyspyder2039 View Post
    Maybe include a link to your listing?
    2014 RTL Platinum
    I too, was the owner of a 2014 RT-S. I also NEVER had a problem with DESS issues on mine. We traded it off in 2020 with 45,000 miles to purchase a 2020 F3L. Someone got a good 2014 there. Would I buy a 2014 again, yes, but I would check the service history for DESS issues.
    INDIANA, USA
    Quote Originally Posted by Dwight View Post
    Dwight
    Well Dwight, I lot of good Tips have been Posted.
    Now you need to carefully read, learn and make your own decisions.
    I see that you have been a member of This Forum for quite some time.
    Let us know what you decide moving forward.
    Thanks and I hope you have a great Day. ......
    RT-S SE PE#0192
    Sep 2007
    Topeka, KS
    Thank you sir. We bought a new 2010 RT and loved it, however it didn't show us much love. Warranty repair 7 times during our ownership. We sold it with 16k miles and bought our present Harley. I installed a trike kit on it. Were older and probably won't be doing anymore long trips. Most of our riding buddies have aged out. It appears that the newer 3 cylinder models are better. 15, 16, and 17's appear to be the ones that would work well for us. The RT's are what we are interested in. Kansas by the way.
    Dwight
