No you were missed. I seen people were wondering where you were on the threads someplace on tires I believe.
If in Doubt, Don't Do It!
My Spyder
Thought maybe on a skiing hiatus
2022 RT Sea To Sky
Yep I did see that one and - answered ….. Mike
Glad to have you back Mike, you were missed!
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
Yep, saw all those tire questions, no BlueKnight. Welcome back.
SpyderLovers Ambassador
Hi Mike
I thought you might of gotten, 'under the weather '
Glad to have you back...... : )
ENJOY YOUR LIFE WITH A SPYDER
No one missed you BLUEKNIGHT. I got all the info I needed from your brother, BLUETOOTH.
Of course we all all missed you, Mike
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Well luckily I've have been skiing ...but it's only local for me ( 10 miles drive ) …. Mike quite a bit
Thought you may have had your bindings on too tight and took a header. A broken hard drive is almost as bad but less painful.
I noticed... dug several holes in my backyard looking for you... guess I better go fill em back in. Hey, I found Jimmy Hoffa that way.
No, it's quite obvious that we missed you.
However, our aim IS improving.
HER ride:
2017 RT-S SE6 Pearl White
My rides:
2000 Honda GL1500SE
1980 Suzuki GS850G
My PC / hard-drive Died, so I had to replace it ….
This is good time to bring up something most computer users are not aware of. I really wasn't.
Many, if not most, of you have seen references to the SMART feature of hard drives. You really need to get some s/w that will check the SMART status every once in awhile. HWInfo is good freebie one. I've always ignored it with the thought that my hard drives will last for who knows how long. Well, as Mike found out, they don't. I added a new SSD (solid state drive) to my computer the other day and in the process saw where my cloning program flagged a HD as having 100 irrecoverable sectors. That was the drive with all my active data on it! In short that means the drive could very well be on it's way down the toilet. The only fix for bad sectors is a new HD. I copied everything to the SSD I had just quit using because of the new SSD. I left the problem HD in but it's empty. I'll use it for temporary storage that, if lost, will not be an issue.
The old adage is, "There are two kinds of hard drives, those that have failed, and those that will fail!"
I know now to take a check of the SMART data every few weeks as it's a good way to catch impending disaster.
