Results 1 to 18 of 18
    Default I was gone from this Forum
    Annnnnnnnnnnnnnd it doesn't look like I was missed …... ….. Oh well ….. My PC / hard-drive Died, so I had to replace it …. bought a re-furbished unit on Amazon for $ 150.00 ( included a new mouse and a new key-board )_ ….. took me 1/2 hr. to clear my backed -up E-mails ) …… Mike
    Sep 2014
    USA
    No you were missed. I seen people were wondering where you were on the threads someplace on tires I believe.
    Feb 2020
    Minnesota,USA
    Tires have been the topic, Wonder why you were not chiming in? Makes one think maybe something wrong! Glad it was a only PC/problem, Now, give em hell!...Bill.
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Nov 2018
    Waynesboro, PA
    WB Mike!!
    My Spyder
    2012 RTL , Brown
    Aug 2019
    Stoughton, WI
    Thought maybe on a skiing hiatus
    2022 RT Sea To Sky
    Yep I did see that one and - answered ….. Mike
    Well luckily I've have been skiing...but it's only local for me ( 10 miles drive ) …. Mike quite a bit
    I did a couple mental where is BlueKnight's. You were getting close to getting a message from me.
    And I was one of the looking for BlueKnight's in the latest tire threads.
    Glad to hear it was something minor.
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    Welcome back
    Sep 2015
    Chilliwack, BC. Canada
    Glad to have you back Mike, you were missed!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Oct 2016
    Sebring, FL
    Yep, saw all those tire questions, no BlueKnight. Welcome back.
    Sep 2017
    INDIANA, USA
    Default Hi Mike
    I thought you might of gotten, 'under the weather '
    Glad to have you back...... : )
    ENJOY YOUR LIFE WITH A SPYDER
    Aug 2008
    MA & NH
    Welcome back.
    Jun 2016
    Harrington, Australia
    No one missed you BLUEKNIGHT. I got all the info I needed from your brother, BLUETOOTH.
    Of course we all all missed you, Mike
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Northern Kalifornia
    Thought you may have had your bindings on too tight and took a header. A broken hard drive is almost as bad but less painful.
    Katy, Texas
    I noticed... dug several holes in my backyard looking for you... guess I better go fill em back in. Hey, I found Jimmy Hoffa that way.
    Aug 2019
    southwest oHIo
    No, it's quite obvious that we missed you.
    However, our aim IS improving.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Idaho
    This is good time to bring up something most computer users are not aware of. I really wasn't.
    Many, if not most, of you have seen references to the SMART feature of hard drives. You really need to get some s/w that will check the SMART status every once in awhile. HWInfo is good freebie one. I've always ignored it with the thought that my hard drives will last for who knows how long. Well, as Mike found out, they don't. I added a new SSD (solid state drive) to my computer the other day and in the process saw where my cloning program flagged a HD as having 100 irrecoverable sectors. That was the drive with all my active data on it! In short that means the drive could very well be on it's way down the toilet. The only fix for bad sectors is a new HD. I copied everything to the SSD I had just quit using because of the new SSD. I left the problem HD in but it's empty. I'll use it for temporary storage that, if lost, will not be an issue.
    The old adage is, "There are two kinds of hard drives, those that have failed, and those that will fail!"
    I know now to take a check of the SMART data every few weeks as it's a good way to catch impending disaster.
    2014 Copper RTS
