Installing a fuse block on a 2021 F3 S Special Series
I'm looking to add a fuse block on my 2021 F3s special series. Can it be wired to the accessory wire in the frunk area? or do i have to wire it directly to the battery?
Power the fuse block through a relay that is energized only when the ignition is on to avoid accidental battery drain. So my answer to you is yes -- you'll be using both. Connected to the relay will be the trigger wire, an accessory lead (or another ignition on souce) and a wire from the battery positive terminal.
thank you!!
