Page 3 of 3 FirstFirst 123
Results 51 to 55 of 55
  1. #51
    Idaho
    Peter Thanks for the your support ...... I get dozens and dozens of PM's asking me for info about tires ..... and I answer ALL of them, to best of my ability .... As I stated earlier I don't KNOW everything about tires, especially the " OFF " / ODD brands. .... I do report on what I find for tires that perform at the top of the heap ( which is small because of the sizes we need ) ..... You have provided tons of Accurate info and I thank you for that .... I'm a p*ss poor typist so I try to consolidate my thoughts ....... Mike
    What I would suggest you do, if you haven't already, is write up your recommendations and supporting information that you usually share in a document you keep on your computer. Then when a PM comes in just copy and paste the text of the document into your reply, adding responses to a specific question or issue if one was asked. That'll save a lot of typing and time.
    2014 Copper RTS
  2. #52
    Dec 2013
    Quote Originally Posted by bigbadbrucie View Post
    I hear what you’re saying, but personally I think that way will discourage many. For the computer literate folks, I should think that someone should be able to devise a template that works on this system, especially in this day and age. jmho
    Sure, if you're skilled at that sort of thing you can do anything you want with a computer system/software package, but when you're running a software package that's been developed by someone else with a given set of parameters/to do a given range of things that's been tested & developed over the years to do that range of things reliably, adding in odd bits &/or templates like that makes the platform unique, a lot harder & more expensive to maintain, and without a lot of tedious & expensive testing, you'll never know where adding in a change like that might create an issue by interacting/conflicting with another bit of code... potentially making the platform unreliable & possibly even bring the platform down!
    I can understand why the bloke who pays to keep the Forum running wouldn't want to start paying for tweaking bits & bobs like that; and I can understand why the bloke who does all the admin & software maintenance doesn't want to take it on either.... and as a member & user here, I reckon I much prefer the Forum to remain as stable & reliable as it has been, and as cheap to us as members as it has been too!!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  3. #53
    Apr 2019
    Clinton, MS
    Quote Originally Posted by Lew L View Post
    How about a " templet" that can just be filled in so there is some consistency in the thread????
    Lew L
    I think it was created in the first post of the thread:
    Spyder:
    Type of Riding:
    Suspension:
    Front Tires:
    Rear Tire:
    Current Mileage:
    Comments:
  4. #54
    Feb 2012
    Spring City,Utah
    That's something that's not easy to do..... if at all possible! I don't know if this version even supports them?!
    That said, if you just use the mouse to select/highlight the important bits of the previous post, then copy & paste it into your post before editing out their tire details & putting your own in, you've achieved the same result with just a few clicks!
    Might be a bit harder on a phone, but if you know how to select & copy text then it shouldn't be too hard to paste & edit the details in your own post.
    This is how I created my post. I did a cut and paste from Peter's post,removed his info and added mine. Very simple, easy and sort of quick.
    BTW thanks Peter for the format.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  5. #55
    Dec 2013
    Thank ThreeWheels, he saw the need/want & came up with the thread & format! I just did the sticking bit!
