Results 1 to 4 of 4
    Member TheOldFox's Avatar
    Nov 2020
    Green Bay
    Default Looking for a service guide - not You-tube
    Is there such a guide showing how to remove all tupperware panels for a 2020 RT-L. I have already purchased the service manual thinking it would be in there.o
    Last edited by Peter Aawen; 01-18-2022 at 04:26 PM. Reason: Removed Prefix - this is a 'What is available?' question not a 'How To: DIY' guide. ;-)
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    There is no printed guide other than the service manual. Do a search in the RT specific forums and you will get tons of help. You can start with my thread here:
    https://www.spyderlovers.com/forums/...-Panel-removal
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    You can look it up here as well, I look up instructions for parts here. It is hit or miss depending on the part. if you know your part number it brings back the instructions for that part number you can also search by name as well.
    https://instructions.brp.com/e-instr...anel%20removal
    Example of results...
    https://instructions.brp.com/content...1154,219401166
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
    Sep 2017
    INDIANA, USA
    Default That Would Be Helpful
    ... So no directions for the 'plastic pieces removal'. The service manual includes some information on the process. I have learned a lot from U Tube.
    Good Luck on Your Mission. ......
    ENJOY YOUR LIFE WITH A SPYDER
