Brake lights with key off
Never noticed it before but just added extra flashing brake lights and happened to push on brake pedal with the key in my hand and the brake lights came on.
Just tapped into the brake lights behind the left tailight. Everything else works fine.
16 RT-L
No problem. Brake lights come on regardless of where the key is. Ignition on not needed.
There is usually another way. 2020 F3Ltd.
16 RT-L
Brake lights on all Spyders are live with the key pulled I believe. My 2020RTL is live all the time even with key in hand. Which does cause a problem sometimes when the brake switch module gets sticky. I always look to make sure my brake light is OFF when I walk away.
Always-On circuits
Now try the Horn Button
my 2 yr old grandson found the horn!!!
SpyderLovers Ambassador
Safety First
....Safety First, Just Like Your Car or Truck.
The Brake Lights and the Horn are available at all Times.
Safety First .......
ENJOY YOUR LIFE WITH A SPYDER
I believe Federal regulations require all vehicles have brake lights and horns work independent of the ignition.
Ozzie Ozzie Ozzie
Thanks, all.
now have to get my son to check out the horn button.
Could be awhile as he's working this week. He's 46 so . . .
