Results 1 to 9 of 9
    Active Member Hound's Avatar
    Oct 2017
    Eastern ND
    Default Brake lights with key off
    Never noticed it before but just added extra flashing brake lights and happened to push on brake pedal with the key in my hand and the brake lights came on.
    Just tapped into the brake lights behind the left tailight. Everything else works fine.
    16 RT-L
    2016 RT-L , Blue
    Dec 2018
    Elanora, Qld, Australia
    No problem. Brake lights come on regardless of where the key is. Ignition on not needed.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Hound View Post
    16 RT-L
    Brake lights on all Spyders are live with the key pulled I believe. My 2020RTL is live all the time even with key in hand. Which does cause a problem sometimes when the brake switch module gets sticky. I always look to make sure my brake light is OFF when I walk away.
    Jan 2021
    Descanso, CA
    Lightbulb Always-On circuits
    Now try the Horn Button
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by BertRemington View Post
    my 2 yr old grandson found the horn!!!
    Sep 2017
    INDIANA, USA
    Default Safety First
    ....Safety First, Just Like Your Car or Truck.
    The Brake Lights and the Horn are available at all Times.
    Safety First .......
    ENJOY YOUR LIFE WITH A SPYDER
    Idaho
    I believe Federal regulations require all vehicles have brake lights and horns work independent of the ignition.
    2014 Copper RTS
    Dec 2013
    - it's another International Standard!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Oct 2017
    Eastern ND
    Thanks, all.
    now have to get my son to check out the horn button.
    Could be awhile as he's working this week. He's 46 so . . .
    2016 RT-L , Blue
