Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 82
  1. #26
    Danbury Connecticut
    Quote Originally Posted by Joel The Biker View Post
    This is the first time I have heard of this problem on 2020+ models. I sure hope its not a sign of things to come. I think I will turn off my DESS for peace of mind.
    I'd like to do the same. Where can you do this ?
    IBA #47122
    2020 RT Limited Asphalt Grey
  2. #27
    Jun 2011
    Alamogordo, NM
    If you are anywhere remotely near the Lamonster Garage, I would suggest that you pay them a visit.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
  3. #28
    Sep 2014
    USA
    This is the first I have heard of the newer models having the DESS issue.
    If its not the module try the antenna. This was what the bulletin stated on my model RT. Ignition is not the problem. Or at least thats what the Bulletin stated.
    Warranty should be able to take care of the cost.
  4. #29
    Active Member thereverend's Avatar
    West Monroe, LA
    If you're anywhere near West Monroe LA, I can do it, I have the BUDS with MegaTech License, I have deactivated mine on my 2015 RT.
  5. #30
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by old Timer View Post
    Is it possible to eliminate the DESS, A simple non chipped key would be perfect.
    PM sent
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
  6. #31
    Clinton, MS
    I hardly ever use my chipped key. Getting ole DESS turned off has been great.
  7. #32
    Jun 2015
    Ritzville, Wa
    I haven't run into that problem yet, but you can be sure the first time it rears it's ugly head I'll be ordering the BUDS system and 1 month Megatech license and turning that puppy off.
    Greg Kamer
  8. #33
    Vermont
    I agree with you. I haven't heard anything either on the 2020 + spyder models.
    Also, if anyone has a newer spyder that still has the warranty, and if you get the D.E.S.S. error have your can-am dealership open up a case with BRP and run it thru the warranty. The D.E.S.S module, switch, antenna is covered under the warranty.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  9. #34
    Jan 2022
    Missouri
    2020 RTL the dess and ant was replaced a case was set up dealer said bring it in thanks
    2020 RTL , Asphalt
  10. #35
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    If the DESS module was replaced and you are still experiencing the problem.
    Tell your dealer to check with what BRP has stated WHAT the problem is.
    REPLACE the ANTENNA on the ignition switch body!
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  11. #36
    Northern Kalifornia
    Quote Originally Posted by PaladinLV View Post
    Except for the DESS module itself, the cause of the error is RF overload/saturation or simply put TO MUCH signal received by the antenna.
    This can and occasionally does cause problems with smart phones connected to wifi using 2.4GHz. Meaning if you phone has WiFi On and connected to a network on 2.4GHz AND you place this phone in the vicinity of the ignition switch/key you MAY experience a problem even in good properly working systems.
    OH DAM! I didn't know about that. My phone mount is between the handlebars just below the key switch on my RT 2014. I have no clue what GHz it has or even what a GHz is, but I do have wifi on my phone. I've put my phone in the holder many times when wifi was on and then turned it off when turning on Bluetooth for my FOBOs. Have never had a DESS issue (knock on wood) and don"t ever want one. Thanks for the heads up "AJ".
  12. #37
    Northern Kalifornia
    AJ
    Do you know if the new 5g phones well cause a greater problem?
  13. #38
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    My sentiments exactly, 2dogs! Holy Crap, to say the least!
    Got my curiosity up after reading your and AJ's posting / comments. I looked at the Tech Specs online for my smart phone and the Wi-Fi connections for my phone are 2.4GHZ and 5GHZ. That's an eye opener because I too have my phone mounted in the same position as yours. I don't often have the wi-fi connected, but you can bet it'll never be on from here on out.
    A huge THANK YOU to AJ for posting this info.
    2014 RTS Pearl White
    2014 RTS , Pearl White
  14. #39
    Oct 2021
    Wichita, KS
    5G has nothing to do with 2.4 GHz or 5 GHz wifi. 5G is the technology the phone network works on. 5 GHz wifi should not interfere with the DESS system.
    Peter Pan has struck again!
  15. #40
    Sep 2014
    USA
    I had nothing on my handlebars and the DES message came on. Will see what happens this year since I put the new antenna on last year but never really drove the Spyder.
  16. #41
    Sep 2014
    USA
    Quote Originally Posted by Jcrozzb View Post
    So you had the Module and the Antenna replaced now??
  17. #42
    Northern Kalifornia
    Quote Originally Posted by FrogmanDave View Post
    "Should" seems to be the perfect word to use at this time. In my research, I've found that no one really knows. As time passes more and more people will be gravitating to 5G and even faster speeds. Right now the airlines are not really sure they like it. If I read it correctly, 5G should/may be less detrimental to our DESS system than 2.4G. However, the close proximity of our phones to the DESS poses a good question. Time it seems will only tell. For now I'll just try and make sure the wifi is turned off on my phone before placing it on my spyder.
  18. #43
    Oct 2021
    Wichita, KS
    As I stated above, a 5G phone network has absolutely nothing to do with a 5GHz wifi signal. Two totally different technologies. The names may be similar but that is where the similarity ends.
  19. #44
    Just like 2G, 3G, & 4G referred to the 2nd, 3rd, & 4th Generations respectively of mobile/cell phone technology, the 5G bit in 5G phone service actually refers to the FIFTH (5th) GENERATION of the applicable telephone technology, & not specifically to the frequency that it uses. It's just the number followed by a 'G' that confuses....
  20. #45
    Northern Kalifornia
    Thanks, Dave. I'll try digesting that. Understanding similarities that have nothing in common with one another is at best..................confusing.
  21. #46
    Feb 2015
    Las Vegas
    If your phone is lying near the ignition switch a problem can occur.
    I cannot remember if it's the Bluetooth or Wireless but I believe it to be the 2.4GHz wireless.
    Now when I say near, I mean like lying in the space right next to the switch. Resting it on the toggle switches or mounted on the handle bars will NOT effect a Properly Operating DESS system.
    AJ
    2014 RT-S
    2014 RT/S , Black
  22. #47
    Feb 2015
    Las Vegas
    Guys, ALL of THIS has been covered in great detail Under Deanna's Thread YEARS AGO!
    All the tech, all the answers, all the questions.
    If you get a DESS failure, the Shop needs to take the following repairs, in the following order PER the BRP Service Bulletin.
    1. Replace Antenna!!!
    If that does NOT fix the problem
    2. Replace DESS Module.
    BRP took years to figure this out as they first started with just DESS, moved to replacing BOTH (both meaning module and ENTIRE ignition switch), then finally sometime in 2016 realized that in the majority of cases, the antenna was the problem.
    I believe it was antenna LENGTH and just a little difference made a HUGE difference, but since they also upgraded the DESS in 2015 they may have found a double problem since the antenna replacement did not become the priority repair until late in 2016.
    The system works like an airplane transponder.
    Signal sent from DESS thru antenna to chip in key.
    Key chip trips and sends code back to DESS via the same antenna.
    As stated earlier, a bad antenna becomes saturated by DESS signal thereby, not triggering chip in key.
    Your windshield Toll Passes like the ones used in places like NY, NJ, MA, CA, elsewhere work the same way.
    AJ
    Last edited by Peter Aawen; 02-08-2022 at 03:01 AM. Reason: Many posts = thread. ;-)
    2014 RT-S
    2014 RT/S , Black
  23. #48
    Jan 2022
    Missouri
    Quote Originally Posted by Lew L View Post
    Hi J,
    Still under warrantee??? Get the dealer to open a case with BRP while giving you a loaner. New bikes shouldn't have this problem and if they do the dealer and BRP really needs to take care of it promptly. Poor customer service doesn't sit well with the buying public-----
    My DESS problem occurred out of warrantee ( but not by much). Replaced the DESS module myself and no more problems since.
    Lew L
    Thanks still have 4 years left this is my second dess
    2020 RTL , Asphalt
  24. #49
    Jan 2022
    Missouri
    Happened again towed after 8000 miles I have read and appreciate all suggestions is any one fixed the check key error while on the road
    2020 RTL , Asphalt
  25. #50
    Sep 2014
    USA
    Never did hear if the antenna was replaced or not.
