Page 1 of 3 123 LastLast
Results 1 to 25 of 60
    Aug 2019
    Stoughton, WI
    Default Might just try a snow tire for normal season riding
    ** THIS TIRE WILL NOT BE USED IN SNOW **
    Like many others, I devour the the tire threads, seeing what is considered the latest and greatest. Thinking back to my days when I was "trooping" in WI winters, my tire of choice was the Goodyear Ultra Grip winter tire. I was so impressed with the quality of traction, that I actually left them on year round on all four corners. I likely put on several hundred thousand miles on them. Now, perusing tire sites, I see that Goodyear actually makes the Ultra Grip winter tire in a 215/60R15. No longer available from Walmart at $88 , I do see it for $145/delivered. While my Cooper CS Ultra A/S still has plenty of tread, I'm considering the traction properties of a full time snow in the back. Hell, it's mid winter in WI, I have to ponder something for the next couple/few months
    * Picture shows with studs. It comes w/o studs*
    2022 RT Sea To Sky
    I have found that snow tires will "impede" your progress. The two front tires act as plows if you get into snow of any depth (about 5 inches). The rear wheel will just spin. If you get into a coating of ice, you are all done.
    And for those who read the operators manual, we are cautioned that Spyders are not for snow driving or driving through water.
    Studs were allowed in Alaska, but most lower 48 states outlaw them. They tear up the roads. Alaska is known for its "grooved" roads from the winter tire stud action.
    Enjoy.
    Aug 2019
    Stoughton, WI
    I have found that snow tires will "imprede" your progress. The two front tires act as plows if you get into snow of any depth (about 5 inches). The rear wheel will just spin. If you get into a coating of ice, you are all done.
    Enjoy.
    Ha .. I guess I should have been a bit more clearer. The tire will be for my NORMAL riding season. I WILL NOT be riding in snow. My Spyder is in a deep state of hibernation
    2022 RT Sea To Sky
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    I know of one other Spyder rider that put a snow tire on the rear. He never reported back how it went. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Quote Originally Posted by Tango View Post
    The owner of a dealership in Alaska tried snow tires. He went to work on the Spyder one day, and that was enough. I followed his advice.
    Sep 2020
    Middletown, NJ
    The Q5 is essentially a winter (snow) tire also. They may be useless in snow/ice but still be better gripping cold roads. I definitely feel a difference after switching to the Altmax that breaks loose much easier than the Q5 did,
    2020 RT base , Chalk White
    May 2017
    Mesa, Arid-Zone-A
    Just looking at the picture of the tire, to me, it looks like more of an all-season (M+S) tire and not particularly an aggressive snow tire. (Except for the studs). But I cannot imagine any condition, that I would want to ride in, when it could provide any advantage..... Jim
    Semper Fi
    Aug 2019
    Stoughton, WI
    Basically, other than tread life, a snow tire will perform very well on dry/wet pavement. The rubber compound is designed to be softer/more pliable than all season/summer tire rubber to grip better on ice/snow/cold pavement. One other small negative is that snow tires will be slightly less effective in preventing punctures due to the softer compound. They also maybe be a bit noisier due to the tread pattern. That's a reason why you see treadwear ratings of 400 on the Vredestein's.
    2022 RT Sea To Sky
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    From what I have read on tire manufacturers websites and my experience with being lazy with my wife's care during Covid, running winter ties in the summer is not generally such a good idea.
    1. They will be too soft and not steer as well at warmer temperatures.
    2. Braking distances are nowhere near as good at warmer temperatures.
    3. Wet weather grip at higher temperatures is not so good.
    4. Traction in the wet or when braking or turning is reduced even more when the accelerated wear is occurs.
    5. Running winter tires in summer at low pressures makes all the above problems more marked.
    6. There is some possibility of tire failure but I think that is much more likely given a heavier car or SUV at high speeds.
    Me, I would stick to mud and snow all season tires as a compromise. They will be cheaper, perform better, run quieter and last appreciably longer. When it gets to the temperature where snow tires are better performers than the all seasons it's probably time to put it away for the winter.
    That's just my opinion.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
    Jul 2021
    IL
    Wow, it never even occurred to me to consider snow tires for the Spyder or any motorcycle that I have owned in the last 40 years. Even without a drop of snow or ice on the road, when it's cold enough to worry about anything freezing its too cold, in my opinion to be riding in anything but a heated car or truck.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Oct 2017
    Kansas
    Hey Troop,
    Interesting looking tire that comes with pretty good reviews. It is definitely listed as a winter tire and with the directional tread design and lots of drainage sipes. It looks like it may be a good choice for the rear tire of the Spyder and like it would be an excellent tire for wet traction. I see your second post that you don't ride in snow. Neither do I. That would not be my cup of tea on the Spyder, especially the older one like my 2009 GS with it's in your face overly aggressive traction control.
    Goodyear doesn't list the UTQG (Uniform Tire Quality Grade) values on their website and they have "N/A" listed for the estimated tread life...so it is probably a pretty soft rubber compound that will wear out more quickly that the typical all season touring tire. One thing that stood out on the Goodyear specs is that the thread depth is listed at 13/32 inch. This is significantly more tread depth than the Vredesteins 10/32 inch. All in all though, this might be a good thing for wet traction vs. harder, longer wearing tires, and the extra tread depth will help durability.
    Note the diameter of the Goodyear Ultra Grip Winter in 215/60R15 is listed at 25.2"
    The VRedestein Quatrac 205/60R15 is listed at 24.8" (I have the Quatrac 5 in this size on my 2009GS and a new Quatrac, also in 205/60R15 waiting for the time to install on the new RTL. This seems to be the most common size used for Vredestein tires on the rear of the Spyders)
    The VRedestein Quatrac 215/60R15 is listed at 25.5"
    If you get the Goodyear Ultra Grip Winter, let us know how it works out. On paper, it looks like a great choice for wet traction.
    Northern Kalifornia
    Been trying to post a link to adjustable zip tie tire chains but the links won't post correctly. Check out zip tie tire chains.
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    HERE YA GO, https://www.youtube.com/watch?v=Pc3xsqWjgzY
    T.P.
    Idaho
    https://www.spyderlovers.com/forums/...=1#post1613825
    2014 Copper RTS
    Northern Kalifornia
    Quote Originally Posted by T.P. View Post
    Hey, Thanks T.P. Maybe stuffing a half dozen of these things in the bottom of your frunk for wintertime may not be a bad idea. They could assist you to get home and into the garage safely under tuff circumstances. To ARtraveler, these things are not studded with metal studs. They are all plastic.
    Feb 2012
    Spring City,Utah
    Utah does allow studs and even requires them in certain areas and times of the year.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Apr 2021
    Ky
    I have a mud/snow tire on the back of my 2 wheel HD. Original tire lasted 10k, this Goodyear has only given up 1/32 in 5k miles.
    I say go for it. I will be following your results for when the wife kills the rear on her 21 F3s
    Sep 2017
    Durham,Maine
    Wow, I am worried about Mike, a tire tread and he hasn't made one comment yet!!!
    2012 RTL , Pearl
    Aug 2019
    Stoughton, WI
    GUYS .. GUYS ...GUYS ... FORGET about the studs. This will be a normal riding season tire. My F3S is in hibernation here in Wisconsin
    ** Tire ordered today. Will not be able to give input for a few months I'll keep apprised **
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    Tire arrived today. It does look more like an aggressive all season tire versus a pure snow tire. Gonna be a bit before I swap it out.
    2022 RT Sea To Sky
    Feb 2020
    Minnesota,USA
    Troop, I like it ! My only concern is will it be a mud slinging stone thrower after crossing some gravel patches.
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Aug 2019
    Stoughton, WI
    I won't find out till late March/early April. Heck, I'll wait for 45* + day to R/R it
    2022 RT Sea To Sky
    Sep 2014
    USA
    Holey crap looks like a truck tire.
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    You couldn't pay me enough to ride in snow.
    With idiots around me who think their 4WD and AWD vehicles are immuned to the natural laws of physics, it would pretty much be a death wish.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by Peacekeeper6 View Post
    With idiots around me who think their 4WD and AWD vehicles are immune to the natural laws of physics, it would pretty much be a death wish.
    +1 And--- it's as though "they" forgot how to drive in the snow over the summer, fall and spring.
    Lew L
    2014 RTS , Circuit Yellow
