Results 1 to 6 of 6
    Jan 2022
    Wisconsin
    Default Any advice on Adding charging port to 2019 Spyder F3 S?
    Any suggestions on how a putz can easily install charging ports on my F3 S?
    Aug 2019
    Stoughton, WI
    Easiest way? Buy one of these .. https://www.amazon.com/NOCO-GC018-Ad...e%2C95&sr=1-14 and something like this .. https://www.amazon.com/AmazonBasics-...ve%2C97&sr=1-4 Cut off the rings and run the power to the accessory connection under the left side tupperware cover. Connect using spade/bullet ends and simply zip tie the connector to the handlebar. Likely the easiest and cheapest.
    2022 RT Sea To Sky
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    I did similar to what Troop suggested, but my charger is USB ‘C’ type, with a higher output. I can use my mapping software on my Iphone 12 all day, and still have a charge.
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
    Mar 2021
    Arizona high country
    I installed one of these. Works great and won't break the bank
    https://www.amazon.com/YONHAN-Motorc...s%2C252&sr=8-4
    Aug 2019
    Stoughton, WI
    I also use the dual USB type, but suggested the female cigarette lighter type + dual USB male adapter for overall versatility
    2022 RT Sea To Sky
    Florida Swamp
    2019 F3-S has a user accessory port under the left side inspection cover. Just plug it in there.
    2019 F3-S , Black & Silver
