Results 1 to 7 of 7
    Aug 2019
    Stoughton, WI
    Default Aftermarket threaded collar rear shock adjustment
    Hey all F3 owners,
    I will soon be upgrading my rear shock, and to this point, I'm leaning toward one that offers a remote hydraulic preload adjuster. Looking under the Spyder F3S rear fender, it would appear that the threaded lock rings would be a PIA to access. Being a 100% solo rider, I'd likely only be making adjustments a few times a year for when I add my (3) pieces luggage/gear/mounts. All are about 80# combined. To those of you F3 owners with a aftermarket rear shock, how is the access to the adjustment rings? Adding the remote preload adjuster adds anywhere from $200-250. to the shock cost, but it also adds a cool look. Thanks for input.
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    I just watched a M2 shock video. The aftermarket spring looks quite a bit shorter, and it would "appear" that the lock rings would be a bit easier to access. I'll need to call Marcus Monday. I know he can't do a shock with hydraulic preload.
    2022 RT Sea To Sky
    Aug 2018
    Chicago
    Have elkas front and rear no problem with adjusting them
    2015 f3s
    Aug 2019
    Stoughton, WI
    Ordered a Wilbers 640 HPA shock for the rear..
    2022 RT Sea To Sky
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    If you cn wait a few weeks, a durch company is developing front/ rear shocks for F3, and it will come with a hydraulic preload adjuster, I will test these thorougly, and come back to you with the answer, price and so on
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Aug 2019
    Stoughton, WI
    That's OK.. I'm happy with my Wilber decision. Thank you
    2022 RT Sea To Sky
    Jan 2019
    Hunter Valley NSW Australia
    I second the wilburs, I have them on my RTL with ther rear remote adjuster that mounts under the seat
    2017 RTL
    2017 RTL , White
