Monster Fuel Injection Canada - anyone had a reflash done?
Are there any folks out there in Spyder land that have had their PCM reflashed by Monster Fuel Injection in Canada?
If so: could you share your results please?
You might know this, but https://wick-itperformance.com/ is the USA affiliate. Same flash.
2022 RT Sea To Sky
yes have both of mine done stage 2 very good people
Yes, I have a stage 1 flash. It's great, no problems at all.
Lew L
Ozzie Ozzie Ozzie
Reason: g eet?? :-/
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Had the Stage 1 flash done by Wick It on my previous 2015 RTL. when I traded for a 2020 RTL, I bought the flash file and the programmer from Monster so I could flash it back in the event of a warranty issue. No issues either time. It is by far the best upgrade you can do to your Spyder.
2020 RT Limited Deep Marsala Chrome
It’s a must for performance.
2021 Spyder F3-S Special Series
Monster Fuel Injection Stage II
K&N Air Filter
Lamonster Cat Delete Pipe with Baffle
Akrapovic Sinister Exhaust
Ultimate Floorboards
Baja Ron’s Anti-Sway Bar Kit
Elka Shocks Stage 3 Front, Stage 4 Rear
F4 Customs 32” Windshield
Pedal Commander
Lamonster F3 Brake Rod
Shad SH36 Side Cases
Crampbuster
Does anybody know if Wick-it carries the "MyGenius" controller that MFI Canada has on their website? I really like the idea of having multiple "programs" & being able to change them at will.
I got the MyGenius and multiple flashes directly from MFI Canada.
My Mods:
Elka Stage 5 rear shock with spring preload adjust
Monster Stage 2 ECU
Pedal Commander
RLS cat delete
Baja Ron sway bar
Baker Air Wings upper and lower
Viking saddle bags
Third pegs
Vredestein tires front and rear
Mad Stad windshield
X-creen windshield deflector
Front and rear drive cam
Garmin Zumo XT
Heated gear wiring
Lamonster LED headlights
Lamonster LED foglights
Lamonster frame mount cupholder
BRP heated handgrips
Lamonster drivers backrest
BRP passenger backrest
Lidlock handlebar end helmet locks
Barkbusters Storm handguards
Checked with them mid last year and they do not. They will be happy to flash your ecu if you send it in or stop by.
Is there a difference between the My Genius and the Power Vision 3? Both store multiple tunes and can be re-flashed anytime.
