Results 1 to 20 of 20
    Oct 2021
    florida
    Default 2018 RT leaking coolant - Any suggestions before dealer?
    I changed the coolant on my 2018 RT and it now is leaking a few drips every day. I tightened the clamps but still no success in stopping those pesky drips I see every morning. Anybody have any suggestions before I take it to the dealer to have it looked at?
    Sep 2017
    Durham,Maine
    First thing I would do is find where it's leaking!! Maybe you spilt a little and it is on top of the covers under there and dripping out slow! I would not tighten that clamp anymore unless you're sure it's coming from that area. If it's spilt fluid, maybe a good hosing, let it dry, ride it and check it out again!! Good Luck!!
    2012 RTL , Pearl
    Jan 2021
    Descanso, CA
    Mikey is correct about checking the overflow tube and giving everything a good wash.
    WRT to clamp: where did you disconnect the hose -- right-hand radiator or cross-over manifold? Both are a bit fragile, especially the ABS manifold. The previous owner disconnected the hose from the manifold and it took more force than I liked to remove it. And what type of clamp did you use -- Oetiker or constant torque (https://www.amazon.com/dp/B00N9AEH0M). Any other type of clamp could damage your hose while not sealing properly.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Oct 2021
    florida
    Thank you for your response to my problem. Looks like the clamp is not the correct type. I followed the link you added. Is the clamp you recommend B00N9AEHOM? Does this require special pliers to? I'm sorry to sound ignorant. We are new to the Can Am family and appreciate any help as we learn our way through our new exciting journey.
    Jan 2021
    Descanso, CA
    Yes that is the clamp. No special tools required except 8mm hex socket. And yeah you get five. So I have four extras, one of which I will mail you. Expect PM shortly.
    Last edited by BertRemington; 01-13-2022 at 03:15 PM. Reason: Provided socket size
    Northern Kalifornia
    Before you dig into it too far as mentioned above find the leak location first. I've double clamped before and had success with stopping a leak. That's the easy way if you have the room and kind'a okie fyed; but if it works it won't hurt anything.
    Sep 2017
    INDIANA, USA
    Default Leaking Coolant
    You need to carefully inspect all of your Spyder hoses. Use a good light to see and find the leaks.
    Is it a clamp or a hose problem? Another possibly could be the water pump or even the radiators.
    Coolant leaks on your Spyder can be a real problem to find. I just found out that I had a small leak from the hose at the over flow tank. I tighten the hose clamps.
    Good Luck on Your Mission. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Oct 2021
    florida
    Love your spyder, ours is blue to. Pretty sure now our issue is the clamp. Appreciate everyone's response and suggestions very much!
    Jan 2021
    Oklahoma City
    kind'a okie fyed
    Hey hey hey
    Northern Kalifornia
    Quote Originally Posted by Adventurer View Post
    kind'a okie fyed
    Hey hey hey
    Yea I know. But, if you've ever ridden dirt bikes you learn that kind of stuff. How to fix anything with black tape a screwdriver a pair of pliers and a stick. LOL At least it gets you back to the truck.
    Sep 2017
    INDIANA, USA
    Default Oetiker Hose Clamps
    Quote Originally Posted by linda502 View Post
    Just realized that most of the clamps on my Spyder are the 'Oetiker type'.
    This type of clamp is a 'one time use' and NOT adjustable.
    I had a radiator hose that was leaking and let my local Spyder Dealer make the repairs.
    As someone posted, you can use a new clamp 'constant torque type'. This is a good choice too.
    I had my Spyder Dealer do a Coolant Service and repair the leak issue. I wanted some peace of mind. They did a good job and well worth the money.
    Northern Kalifornia
    "Oetiker Hose Clamps," One good reason to leave it there and double clamp next to it, if there's room, with an adjustable high pressure clamp. Good luck.
    Sep 2017
    INDIANA, USA
    Default Coolant Leak
    ...Just Curious What You Did?
    What did you end up doing about your coolant leak?
    Sep 2017
    Durham,Maine
    2012 RTL , Pearl
    Oct 2021
    florida
    Thank you everyone for your very helpful advice! Changed the clamp and replaced the fluid, again, and no more dripping. Yay! I ordered a shop manual and that came and so the Mister will have lots of reading to do. The shop manual will be very helpful. We have a 2018 RT SE and it is certainly a lot of fun! Bike week in March in Daytona Beach will be a lot more fun this year!
    Jan 2021
    Descanso, CA
    Talking Coolant leak fixed with constant torque clamp
    Little Blue and Mikey -- put the popcorn down -- Linda's clamp solution is this https://www.amazon.com/dp/B00N9AEH0M
    Oct 2021
    florida
    Forgot to mention using a long flexible flashlight shining into the overflow bottle shows your fluid level and we're spot on! Exactly one gallon so says the shop manual. That was a crafty idea that works great.
    Sep 2017
    INDIANA, USA
    Default Constant Torque Clamps
    Quote Originally Posted by BertRemington View Post
    Thank you. I know about constant torque clamps.
    I have used them and they are great.
    Most people don't like the idea of having to pay for them.
    They are expensive to say the least.
    Have a Blessed Day Everyone. .... : )
    Sep 2017
    INDIANA, USA
    Default Flashlight
    If you are removing the radiator cap/coolant tank cap be sure you install the cap correctly. Why, because you can make a leaking cap issue.
    Ask me how I know. .....
    I now use a pin light and shine it onto the coolant tank to check my level. .... : )
    Quote Originally Posted by Little Blue View Post
    Also a likelihood it will over-heat .... The system has to be sealed tight for it to work properly ..... jmho .... Mike
