Results 1 to 13 of 13
    Nov 2011
    Gillespie, Illinois
    Default Anyone used Castrol Full Synthetic? Results?
    Has anyone used Castrol Full Synthetic oil (5W40 4 stroke) in their RT 1330? I have a 2018 and was wondering if anyone had used it, what they thought about the results. Thank you.
    2015 RT LTD , Red
    Sep 2020
    Middletown, NJ
    I've used it twice on my '20RT (18k) with no issues. I used it in my Trophy SE and Versys 1000 without any problems.
    I'm going to try Amsoil for the 1st time at next change.
    2020 RT base , Chalk White
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    I've been told by a spyder tec that BRP oil is Castrol. But I think the BRP oil is a blend. I've used Amsoil full synthetic in my RT with no problems.
    Happy owner of 2014 White RTS - SE6
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    Quote Originally Posted by Spyderjuice View Post
    Last time I looked. BRP branded oil is not "JASO" rated. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Apr 2020
    Edgerton,WI
    Thumbs up
    Quote Originally Posted by gl1800 View Post
    Yes, the engine is still intact
    2019 F3L , Covid Blue
    Sep 2016
    Chillicothe, Oh.
    Yes. In my 2015 RT and I also had a Trophy SE that used that oil. No issues.
    2015 RT , Black
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    I've used Castrol 1 4T fully synthetic, as recommended, in my 2015 Triumph Trophy and 2018 Triumph Bonneville T120. I know it has a different name in some markets, but they are seemingly equivalent.
    I have never had any issues using it in either Triumph and as the Rotax 1330 triple uses very close to the same technology as the Triumph engines, and they are about the same kind of horsepower per litre output, I would imagine it would be just fine.
    I am sure it is no better, or worse for that matter, than any other name brands - change it every 5,000 miles or so and I think anything semi or fully synthetic from a name brand manufacturer that follows the manufacturers rating requirements especially regarding wet clutch engines will work just fine.
    The thing I am much more fussy about though, is the quality of oil filters. Some of the really cheap ones really are truly awful in construction. All oil brands you use will benefit from better levels of filtration. Your mileage may vary.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
    Nov 2011
    Gillespie, Illinois
    Default Anyone using Castrol Full Synthetic 5W40 in their Spyder?
    Has anyone had experience using Castrol full synthetic 5W40 motorcycle oil in their RT? Mine is a 2018. The specs I'm considering are JASO MA2, APISL. Thank you for your replies.
    Terry
    2015 RT LTD , Red
    Jul 2014
    Mint Hill, NC
    If it meets the API service spec(s) in your operator's guide it's acceptable to use in your Spyder. The ONLY way to tell how it performs is to have it analyzed.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Oct 2015
    Middletown De
    Silly question. If you dont buy the oil change kit where do you get the gaskets and filter ?
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by dragonridernj View Post
    Lamonster Garage--- a sponsor on this site. His Facebook store will sell you the correct filter and gaskets and filter for your Spyder. Always saves time to put the specifics of your ryde in your signature.
    https://www.lamonstergarage.com/oil-change-kits/
    2014 RTS , Circuit Yellow
    Apr 2019
    Clinton, MS
    BajaRon, another sponsor, always has those items in stock. Links on the home page.
    2019 RTL Phoenix Orange
    " gaskets " ??? my 14 RT has had 14 Oil Changes. Never changed an " O " ring gasket .... " Oil filter , changed once per year, they come with a new gasket attached. ...... Mike ..... PS , I remember back in 2011, lots of folks were changing out all their Wheel BEARINGS .... EVERY time they changed tires. I've had three spyders well over 100,000 mi. Have not changed a bearing yet and have not had any Bearing failures. ..... JMHO .... Mike
