Results 1 to 10 of 10
    Dec 2021
    SC
    Question CB Question for 2021 F3-T
    is anyone using A Midland 75-822 CB on their F3-T?? If so what bracket did you use to hole it on with?
    Sep 2008
    TX
    F3-S, so a little different windshield mounting. I made a clip on adapter for a 1" RAM ball mount system. Wired the PTT and headset out to the left handlebar. Hardwire connection to helmet speakers. The bigger issue is to use an external NGP antenna and tune the SWR. Otherwise range will be very short. With the NGP and proper tuning, I could get more range than my H-D OEM CB.
    Full disclosure: we no longer ride with large groups so I removed the CB.
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Actually an old topic.
    I pulled up an older photo, could not find mine.
    Most were using the Midland with the Sena SR10
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Linden, CA
    Quote Originally Posted by Jeffd View Post
    I have the holders in stock
    give me a call 209-887-3283
    May 2017
    Mesa, Arid-Zone-A
    An antenna option is to look at Firestick CB antennas. You want one that is specifically for no ground plane (NGP). They work well..... Jim
    Semper Fi
    Aug 2013
    SF Bay Area
    I use one mounted to the center of the bars. I use a Sena SR10 with PTT external button routed to the left grip area. So far, I use the built-in antenna. I also have the a 12v docking station to power and mount the radio using a RAM ball and arm. I use a USB A Male to 12V Car Cigarette Lighter Socket Female Converter to power it from the 12v USB. (just one)
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2021 F3 Ltd , Magna Red
    Linden, CA
    I have the mounting bracket in stock for that unit call me 209-887-3283
    Feb 2015
    Las Vegas
    Flamewinger
    Just an FYI
    As a long time CB'er easy 60s and HAM Radio Operator (N1BCK) CB's as well as hand held HAM radios are PRIMARILY for use with a Vertical Antenna. They will transmit & receive with either the vertical or what is called a HORIZONTAL.
    The difference between the 2 are BASICALLY how they are positioned.
    RF energy is such that a Vertical Antenna will receive a substantial loss in receiving from a Horizontal and visa versa.
    In the end, your choice, but are are not going to get the range or quality from the transceiver with you antenna in a horizontal position.
    AJ
    2014 RT-S
    2014 RT/S , Black
    Linden, CA
    Quote Originally Posted by PaladinLV View Post
    Flamewinger
    Just an FYI
    AJ
    Unless they use stack 5's hahahaha
    Aug 2013
    SF Bay Area
    Been using this for 4 years in Goldwing groups just fine. I only need to hear the few in front or behind me, don't need to hear anyone miles away! Because there aren't any.
