Results 1 to 25 of 27
    Member javaspark's Avatar
    Jan 2022
    South Florida
    Question Anyone tried Handle Bar End Weights? Any good??
    I noticed TRex is offering stainless steel handle bar end weights that supposedly reduce & dampen vibration in handlebars. Not sure I understand the mechanics of that. Anyone have experience using these or similar? Worth it?
    https://www.trex-fab.com/products/ha...ghts-stainless
    Quote Originally Posted by javaspark View Post
    I made some from lead for my GS & RSS ( the Vtwins ) ... it definitely lessons the vibes .... I got the lead from a friendly garage that let me dozens of USED wheel weights ( they normally won't be re-used ) ... Melted them down in a cast iron skillet on the BBQ grill, then poured it into a dimilar size metal tube ..... My 2014 1330 RT doesn't need them I have foam covers for the grips .... Mike
    Aug 2020
    Il
    I'd try the foam grips first...and did. Lessened the vibration quite a bit.
    https://tricledusa.com/products/the-...for-all-spyder
    Active Member KnurledNut's Avatar
    Jul 2021
    Favoretta, FL
    I use the weights from Slingmods. They made a definate difference in vibration. Not 100% but close to 90%.
    2021 , generic
    Sep 2016
    Chillicothe, Oh.
    I don't have a Ryker, but I do have the bar end weights on my two wheeled bikes. They work well.
    2015 RT , Black
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    More front end oscillation than bar vibration, ain't it? I've been toying with the idea of adding a damper to the steering to see if there's an improvement there. Worked wonders on my Ural sidecar rig. Seems like the center tie rod that runs along the top of the motor would be a perfect place for one on a Ryker. The Ural's got a VW jetta damping shock mounted up now, but it'd take a bit of math to get one that would apply the correct amount of damping on the Ryker..
    PS - I've seen where folk load the bars with lead shot. A bit of silicone at the ends to lock the pellets in place and yer done.
    Half a million miles, and I ain't dead yet.
    See my album at https://www.spyderlovers.com/forums/...p?albumid=5190
    I added handlebar weights on both my 2008 and 2009 GS & RS. They seemed to be needed, and they did help when I added them. That being said, I have not put them on any of the other five Spyders.
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Quote Originally Posted by KnurledNut View Post
    They look cool too! Less vibration for sure.
    Feb 2012
    Spring City,Utah
    Never ridden a Ryker but they work really well on my 2012 VTwin Spyder RTL
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jan 2022
    South Florida
    Seems the consensus is that end weights do work. I also like Pirate's suggestion to try foam grips.
    Lot's of good advice. Appreciate the input!
    May 2016
    Noblesville, Indiana
    I have 40,000 miles on my 2019 Rally with foam grips and see no need for weights.
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    Changing the mass of the bars (with weights) changes the resonant frequency to something more pleasant. It's been a thing on motorcycles for a long time. Many motorcycles have them as original equipment.
    Oct 2021
    Texas
    Great info!
    Jan 2022
    California
    Handlebar weights reduce vibrations. There are many ways to reduce vibrations but handlebar weights is one of the cheapest and it is focused to remove the tuning fork effect and keep your hands from going to sleep.
    Quote Originally Posted by sKiZo View Post
    Sounds like a" band-aid " to fix un-balanced wheels / tires ..... JMHO .... Mike
    Active Member TIMEMACHINE's Avatar
    Feb 2021
    King George, VA
    The T-Rex and Slingmods handlebar end weights are made by Show Chrome. I’d love to see someone make something proprietary for our Rykers and not a universal part.
    2020 Ryker 600
    Feb 2022
    Mississippi
    I did Slingmods bar end weights and foam grips for my wife’s 2018 Spyder RT Limited SE6. She says she loves the changes; I can definitely notice a difference in handlebar “buzz”.
    Gregg L
    2022 RT Limited, 2020 Indian Challenger Limited
    Feb 2022
    TX
    I plan on getting some bar end weights. The vibration alone makes the mirrors almost useless at times due to the vibration in the bars.
    Feb 2019
    Portland, Oregon
    Loosen the drive belt to 160 rear wheel on the floor, 140 off the floor. Measuring with a Krikit II. That got rid of my vibes and I put Lidloks on my handlebar ends.
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Default Vibration in handlebars
    I also added the handlebars chrome end weights and foam grips to my Spyder. It definitely helped with the small amount of vibration I was getting in the grips. No more sleeping hands .
    I
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    Just ordered some from Trex fab, on sale right now for $30.00.
    Jan 2022
    North Dakota
    will the same ones that fit a Ryker fit a RT?
    2021 RTL , Asphalt Gray
    Feb 2022
    TX
    Thanks for that. Just ordered a set!
    Apr 2021
    North Carolina
    Quote Originally Posted by ziggy View Post
    Well, I've taken two rides since installing the end weights. Did about 60 miles yesterday. YES, they DO help...
    Oct 2021
    Ontario
    Thanks Guys... Still on sale at Trex... Just ordered a pair myself!
