Results 1 to 5 of 5
    Active Member thereverend's Avatar
    West Monroe, LA
    Default What differences between levels of BRP's BUDS licenses?
    Does anyone know the differences in the megatech licenses verses the all dealer license with the BRP BUDS Software?
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Mechatronic Expert License Features:
    Changing of the VIN number, MODEL number
    Advanced settings
    View stories in hours, rather than percentage
    Enabling / Disabling DESS
    Change the key type without reprogramming (normal, learning, rental)
    Clear the history of the blocks ECM, MPEM (history of substitutions)
    Cleaning ECM, MPEM, CLUSTER "as new" (resetting the hours to zero and miles/kilometers)
    View more information blocks
    Installing Secure Code
    Edit curves for 2-Stroke vehicles and new E-TEC (Skidoo).
    All Dealer License:
    Using BUDS / BUDS2 program, you can:
    Edit vehicle information
    Test, add or remove DESS keys
    Adjust engine parameters
    Activate module outputs
    Stop the engine
    Monitor vehicle parameters
    Troubleshoot vehicle faults
    Replace a module
    Update module software and/or calibration data
    Read and reset historical data
    Save vehicle information to disk
    Print vehicle information
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    West Monroe, LA
    Thanks
    Dec 2015
    Oakley Utah
    Is this the kit i would want to get? https://www.powersports-diag.com/en/...erface_unit-no
    2014 RTL Platinum
    Sep 2020
    Middletown, NJ
    Looks like you can save a few pennies if you only need Spyder/Ryker version.
    2020 RT base , Chalk White
