Results 1 to 25 of 46
    Nov 2019
    England
    Default Need a New battery - what type: Lead Acid, AGM, Gel?
    Need a new batteryfor my 2016 spyder rt limited. Can't decide between lead acid, absorbant glass mat or gel. Has anybody tried any of the above and were you happy with your choice. Any advice greatly received.
    Nov 2013
    Oro Valley Arizona
    Would not recommend lead acid.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    May 2018
    millsboro,delaware
    The original style battery always lasts the longest for me. It’s more about the way you maintain it than the type.
    : 2017 RTL ORBITAL BLUE
    Active Member NEXUS's Avatar
    Feb 2008
    Buckingham VA
    NOCO Lithium was my choice.
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by AdyB View Post
    OEM Yuasa battery offers 350cca.
    Amazon has it for 101.42……..regular $150
    2019 F3L , Covid Blue
    INDIANA, USA
    Default Battery
    The OEM Yuasa battery is an AGM.
    The number is YTX24HL.
    They are available from many local stores and online. ....
    ENJOY YOUR LIFE WITH A SPYDER
    If you really want to know what most members here think and recommend do a search on battery. You will get bleary eyed reading all sorts of thoughts and suggestions. If you want to go the generally recommended route just buy the same thing that's in your Spyder now. Be sure it is properly activated before you install it or it may not last very many years.
    Sep 2020
    Middletown, NJ
    I tried a Lithium battery that had higher CCA than oem last winter mainly for the size and weight savings. Epic fail! There wasn't enough power to crank the engine even after letting the battery warm up (ignition on to get the juices flowing.) Went back to the oem and haven't looked back. Li-Ion batteries are great for lots of uses but didn't work out on the RT.
    2020 RT base , Chalk White
    Feb 2019
    Portland, Oregon
    Just be sure to follow all the suggestions in this currently running thread and you will do well. Go with the original - it's the one thing BRP did right and buy local please.
    Thread: 2014 RT Ltd Spyder with new battery won't start! Ideas?
    https://www.spyderlovers.com/forums/...t-start!-Ideas
    Jan 2021
    Descanso, CA
    RayBJ -- I installed a Shorai LFX36L3-BS12 shortly after I purchased my used 2014 RT-S in January and never had a slow start even at temperatures in low 40s. Later I installed an analog voltmeter but it was boring (13.2 resting, 14.4 riding, 12-something starting) so replacing it with an analog clock.
    Note: when installing a smaller battery like an LFX be sure to bend the tangs flat to prevent shorts.
    Always bought OEM batteries--from dealer. Have replaced three or four now. Always do it at four years, whether they need them or not.
    Northern Kalifornia
    My 2nd OEM Yuasa AGM battery was the same price from the local Can-Am dealer as it was online. Don't recall the exact price. But it's much easier to exchange it if it's ever defective than it is to try and exchange it through online dealers. Local dealer exchange is only a 1/2 a day turnaround if that long?
    Mar 2008
    Hesston, PA
    I like the AGM Deka...They have the best cable attaching system...AND THEY LAST...larryd
    Quote Originally Posted by jaherbst View Post
    Jack
    ..... although it could be used ( only because in your Spyder it is mounted " upright " ) .... I don't think you can get one with enough power in the small size ( physically ). .... Just replace with a Yuasa ..... JMHO ... Mike
    Bossier LoUiSiAna
    Unfortunately currently out of stock, good to check with them.
    https://www.lamonstergarage.com/battery-1/
    Somehow a battery thread & someone didn’t mention adding star washers (just an observation).
    Is good time to add some, if your going to
    Where is that guy with the star washers comment???
    I had already mentioned them in s different thread ..... Mike
    May 2018
    millsboro,delaware
    Whatever you put on there if you hook it to a battery tender you will get a lot more life out of that battery. I got 7 years on my GW.
    Jan 2021
    Descanso, CA
    Dec 2015
    Oakley Utah
    All the studies I've read say the gel provides no real advantage over AGM. You don't want a traditional lead-acid in a motorsports machine ever. The only real choice is AGM, which is what the OEM battery is. Yuasa is the OEM brand and is one of the best motorsports batteries, but other brands are good, too.
    Just don't get anything made by Lucas!
    2014 RTL Platinum
    Lithium cannot safely provide the amperage necessary to start an engine.
    Why do you say that? There are quite a few powersports and automobile batteries on the market. I would say don't buy an economy version. They need to have a special charging management system built into them since a vehicle charging system isn't designed for Lion batteries. There are a number of jump starters that use Lion batteries. It looks like good Lion powersports batteries cost $200 to $500. I don't think they could possibly be so much better than AGM batteries to justify that kind of cost.
    Quote Originally Posted by BertRemington View Post
    I just answered your post on this ..... Mike
    Dec 2015
    Oakley Utah
    Lithium batteries are designed to provide a long, slow discharge and quick recharge. They're great for RV house batteries, trolling motors and such. They tend to overheat and even catch fire when called on to provide a high discharge amperage. A lithium battery safely rated at the discharge rate needed for a starter motor would be much larger than the space available in the Spyder battery compartment.
    That is my understanding based on my research. I don't claim to be an expert on the topic.
    2014 RTL Platinum
    Nov 2016
    Upstate NY
    I have a lithium battery in my Spyder and it works fine. There is no special charging system/alternator needed on a vehicle to maintain a lithium battery. The only special charger you need is a lithium battery maintainer for storage. I use Battery Tender brand maintainer that has a selection for lithium.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Joel The Biker View Post
    Joel, can you provide the brand and model of that battery? It's good to know there is a lithium option for those who want one.
    2014 RTL Platinum
