Results 1 to 23 of 23
    Mar 2010
    Pilesgrove,N.J.
    Default 2014 RT Ltd Spyder with new battery won't start! Ideas?
    About a month ago I bought a new battery since my old battery was over seven years old. Since I bought the new battery I have ridden the Spyder three times with the last ride being about five days ago. I had no problems with the Spyder on those rides. Today I went to start my Spyder and this is what happened. Looking for any suggestions as to what the problem may be.
    https://youtu.be/jyOSOfFa3PI
    Mar 2015
    Fritch, Tx
    I would suspect one of two things;
    1. the new battery has a dead cell from the factory so it does not retain a charge.
    2. one or both of your terminal connections did not get quite tight enough and worked loose during your rides.
    actually make that three things;
    3. you have a bad connection at the starter.
    Those who say " I can't" will always be right.
    Nov 2015
    Chardon, OH
    And let's add a fourth thing - Did you do an initial battery charge in order to give the new battery a proper activation charge. In other words, even though you may buy a battery that has the acid already installed, that battery still needs an initial "activation" charge. A dealer or retailer typically doesn't do that. So, if you didn't do it, it most likely wasn't done. If you would ride it daily, that probably wouldn't matter. But in your case, it would. It's not too late - if you purchased the standard OEM type AGM battery, use a battery charger with an AGM setting, and give it a 2 amp charge until the charger shifts itself from Charging to Maintaining Mode. Then leave it in Maintaining Mode until you're ready to ride again. As an extra, purchase a small battery maintainer unit and use that in between rides. In rare cases, there can be add on circuits from the previous owner - if there was one - that are using battery power even though the key is off. But check into all these more common issues first.
    Doug
    ”Freedom is not a loophole”
    Mar 2010
    Pilesgrove,N.J.
    Thanks for the suggestions. I will try charging the battery.
    Feb 2019
    Portland, Oregon
    Never start a hibernating engine. Let it sleep unless you intend to take it out for a long ride. Starting and running for a few minutes harms the battery and a lot more.
    May 2017
    Mesa, Arid-Zone-A
    You didn't say how long you rode your Spyder since installing the new battery. As previously said, a new battery needs to be brought up to a full charge. If your 3 rides were short, like 15-20 minutes, you never replaced the capacity required to start your bike. In effect, what you were doing was drawing the battery down with each ride. OTOH if you rode an hour or more each time then you have another problem like bad battery (it happens), loose terminal, ground, etc. Good luck..... Jim
    Semper Fi
    INDIANA, USA
    Default Battery
    Just curious about your new battery. Did you install the battery or someone else?
    What brand did you purchase?
    Definitely need to ryde your Spyder for about an hour or more each Ryde Time.
    Sometimes you can get a bad battery.
    Have it checked out for a problem.
    Good Luck with your Mission. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Mar 2010
    Pilesgrove,N.J.
    Thanks for all the suggestions folks.
    Quote Originally Posted by djames4 View Post
    Just let me add, if you haven't put STAR washers on the terminals ..... it's necessary to keep the connections tight .... Spyders are known " shakers " ..... good luck .... Mike
    Jan 2021
    Descanso, CA
    Wink Mike -- We Need Your Star Washer Guidance!
    Mike -- Star Washers are subtle technology of the highest order. And we need your guidance on proper installation on our precious rides. So here are our questions:
    1. Do we place a star washer between the bolt and lug?
    2. Do we place a star washer between the lug and terminal?
    3. If we have two lugs (eg, FuzeBlock power) do we place a star washer between them?
    4. If we use a flat washer between the bolt and lug, which side do we place the star washer?
    5. If we use a flat washer between the lug and terminal, which side do we place the star washer?
    Many of us are putting together gift wish lists so we need your unparalleled wisdom soonest.
    Seasons Greetings and all our best to you Mike.
    Quote Originally Posted by BertRemington View Post
    ....IMHO .... The last thing I add to a terminal is the STAR washer, then use a nut ..... good luck .... Mike
    Mar 2010
    Pilesgrove,N.J.
    Tried charging the battery. Still won’t start. Reacts just like it did in the video I posted before. I guess I will have to get it towed to the dealer.
    Feb 2019
    Portland, Oregon
    If you or someone you know has a power pack, try starting using one of those.
    OR .... if you have another veh. (12v) just try using "jumper" cables. ... I would not have the other veh. running, just use their battery ..... Mike
    INDIANA, USA
    Default Battery Issues
    We are trying to help you with your problem.
    It would make things easier if you gave some additional information.
    What brand of battery did you purchase?
    Was it installed by you or a dealer?
    What is the voltage of the battery?
    Add to the story my friend.
    Jun 2011
    Near Lexington, NC
    And did you make sure the terminal bolts tight?
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Jan 2021
    Descanso, CA
    Question
    That Crank speed is very slow!
    djames4 -- that is a very slow starter crank speed.
    Did your seven-year-old battery crank that slowly? How many seconds before the engine started?
    Did your new battery for the first three rides crank that slowly? How many seconds before the engine started?
    How many miles on your 2014?
    Jun 2021
    Midland, MI
    so what did the problem end up being, mine is doing the same thing
    Nov 2022
    CA
    Hey Spyder Heads, just wanted to share my experience with my 2014 Spyder RT.
    I've been having issues with the battery dying way faster than usual. I've just noticed a something - I'm now thinking the Bluetooth someway somehow is draining the battery. Either way, I'm sick of it dying out, and I'm hoping I've come up with a possible solution, as drastic as it may be!
    I've decided I'll just disconnect the battery whenever I leave it overnight or on extended days when I may not drive it for whatever reason...
    IDK what else to do, TBH!
    Feb 2024
    Tennesse
    After reading information about Spyder batteries going dead if you don't ride regularly I bought a battery tender for mine like this one:
    https://www.lowes.com/pd/Battery-Ten...ger/1002650248
    It has a short section of the cable that connects to your battery, with a quick disconnect plug and a cap to cover the disconnect joint.
    When you pull your bike into your garage, you uncover the plug and connect it to the "tender" part, which plugs into an outlet on the wall.
    racoon
    Middle Tennessee
    2024 CAN-AM Spyder RT Sea-to-Sky - Vegas White Satin
    2023 Honda Ridgeline Sport - Sonic Grey Pearl (aka Baby Blue)
    2024 RT Sea-to-Sky , Vegas White Satin
    Quote Originally Posted by studiodevil View Post
    If you have some sort of "quick dis-connect" on the battery, that's fine; but if you have to remove one of the battery leads down on the battery, that can be a problem .... could you dis-connect the "blue-tooth" instead? .....Mike
    Clinton, MS
    Is this an add on Bluetooth you are talking about? Simple to test - bike off; go to the Bluetooth section on your phone to see if it is still connected; if it is, you have found your problem.
    2019 RTL Phoenix Orange
    This thread goes back to December 2021 and then one post in 2022 asking if the problem was ever solved. The OP has not been on site for a couple years.
