Is the extra 10 HP for the F3 Sport noticeable over the base F3?
Is the extra 10 HP for the F3 Sport noticeable over the base F3? Because I'm a HP junkie but also looking to buy a used 2018 or 2019 F3S but didnt want to limit my search by not considering the Base model F3.
Is there any way to unlock the extra 10HP on the base F3?
Thanks Spyderlovers!
Steve from NY
Reason: Prefix - This is a 'How do I?' not a 'How to:' DIY explanation....
All the newest Spyders RT and F3 have the same 1330 in line 3 cylinder engine producing 115 hp. I have not heard of any different in hp from one to the other.
Where did you see the F3s had 10 more hp?
Reason: SPELLING
2017 RTL Asphalt Grey Metallic Chrome
I don't know if there is a difference now, but the F3 was rated 105 horsepower at 6,000 RPM and the F3S was rated 115 horsepower at 7,250 RPM.
I doubt there was any noticeable difference at reasonable RPMs.
23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
2020 900 , NGK 4218 iridium CR8EIX Matte black
I have a base 2020 F3 SE6 and don't miss the "extra" 10 HP and 10 MPH. I have plenty of fun on it
Now what you will miss if you get the F3S is the ability to tow a trailer if you so desire.
The bigger sprocket on the F3S takes away your ability to tow anything.
2020 F3 SE6
Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
Tackform Center Mount Phone Holder w/ rapid charging USB-C.
Originally Posted by CloverHillCrawler
I have a "regular" 2020 F3 and don't miss the "extra" 10 HP and 10 MPH. I have plenty of fun on it
Now what you will miss if you get the F3S is the ability to tow a trailer if you so desire. The bigger sprocket on the F3S takes away your ability to tow anything.
Is that what Can-Am says, or are you conjecturing?
2014 RTL Platinum
Steve from NY
I believe you probably could by changing out the rear sprocket and remapping the ECU. BRP had a picture of the differences between the 21 and under base F3's and the 22 base F3. I don't think the 10hp would make a drastic change but more of a subtle one. If you can afford the F3s and are a "HP junkie" then that's what I would gravitate towards. Myself, I am more of a cruiser not a racer so the base F3 is fine with me. I don't need the remapping, Pedal Commander, etc.
Ozzie Ozzie Ozzie
While that might be theoretically possible, AFAIK no one has managed to successfully change the rear sprocket & re-map to avoid the errors & Limp Home conditions that result! BRP have been very successful in their efforts to ensure that changing the sprocket from one size to another is not a viable option!
Basically, it seems that if you've got a given sprocket, then you've gotta keep that given sprocket size! That said sarecco, re-mapping the ECU to gain/re-gain that extra engine power and then some should be quite feasible; but you'd still hafta work with the same sprocket to get it to the ground.... There are tuners in North America (& here in Oz too, where we've got one of the best in ECU Xtreme/RotaxRacing ) who do this for the higher powered Spyders & Rykers already (think Monster Performance & Wick-It ) so accessing all that untapped power without changing the rear sprocket shouldn't be too hard, just a bit of a cost!
Besides, changing your rear sprocket for a larger one won't increase the engine torque; give you more mid range; or change the engine power curve in any way. It will only alter the torque delivered to the ground/at the rear wheel across the entire rev range. So if you could change the rear sprocket for a larger one, without changing the rev limit (which is also safely do-able via a re-map! ) the bike should accelerate faster through the gears but you would loose out on top speed.... IF you could successfully change the rear sprocket - but that's proving to be more than a little difficult!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
2020 and prior base F3's were rated 10hp less than the other F3/RT models. That changed in 2021. The extra 10hp was likely gained thru ECU timing differences. As said in a prior post, the extra 10hp is likely unnoticeable, and can be altered with a ECU flash/PV3.
2022 RT Sea To Sky
In simple terms, if you do the pounds per horsepower of a loaded and fueled Spyder, for an F3 series it is likely around 11 lbs / HP.
A decent stock sport bike is 5 lbs / HP.
Spyder would need to make 200 HP to be close.
Yes PMK, that is a good thing to remind our selves of. The 1330 is quick enough for me as i turn 60 yrs old. Just want the most HP that is available when i decide to purchase my next F3.
Originally Posted by BLUEKNIGHT911
IMHO having a bigger rear Sprocket is going to produce MORE torque, which I think Benefits the ability to tow ..... ...... Mike
I'm just going off of what F3S drivers are telling me from the group I ride with. They all have stated that it is not recommended by BRP to tow with an F3S due to the sprocket size.
2020 F3 SE6
The not towing with the F3S is not due to the rear sprocket size. The sprocket size on the Current (and all) F3S is the same as on the F3T from 2016, 2017, and 2016 F3 Limited. The larger sprocket makes for better off line acceleration and also turns 6th gear into more of a pulling gear than just an overdrive. So the larger sprocket does not make you loose top end like some have said. If you want more power with the current F3 base, just get a computer remap and pedal commander. You will have all that you want, and able to stick with or beat any F3S. But the things that you will not have are the better shocks and cruise control (standard on the F3S). The smaller sprocket has made its way to all the spyder lineup, except for the F3S. I think that is to keep it as the supreme sport version. But as I stated earlier, in 2016, it was in the entire F3 series lineup. That is before the Limited version got the top box. In fact, when I talked to a local dealership (in 2017), they even suggested that if I wanted a limited, to go with a 2016, and add the top box. They said I would thank them for the added acceleration earlier. As for the larger sprocket making gas milage poorer, that is also not true. I have a 7 gallon tank on my 2016 F3T and get more range than both of my buddies on their 2020 RTL. Not sure if the above is documented by BRP, but this is all real world facts from someone who has owned the larger and smaller sprocket versions of the 1330, as well as a 2012 RSS.
2014 RTL Platinum
If a HP vs RPM graph can be found, I would be very surprised if there is any difference in HP between the 105 HP model and 115 HP model, at or below 6,000 RPMs.
Keep in mind that torque peaks at 5,000 RPM.
There's no problem towing with an F3S (a 2019 model is what I have direct knowledge of.) You just can't use a BRP hitch. Pierre at canamspyderaccessories.com has one for the F3S and it's very straightforward to install. I believe Lamont has one as well but would have to double-check that.
Trb-- (Roger)
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Spyder States Visited
