Results 1 to 8 of 8
    Apr 2019
    South Carolina
    Default RT battery change - any data loss when disconnecting cables?
    Is there a problem with loss of pertanent data when disconnecting battery cables?
    Northern Kalifornia
    No, not at all.
    No, not at all.
    .... settings that YOU can adjust like the radio etc. will need to be re-set ....but that's all ..... Mike
    Northern Kalifornia
    Mike, I was hoping when I changed my battery on my 14 RTS it would clear my radio setting because they were all screwed up. Well, it didn't help one bit. I don't know what happened but it didn't work. The battery was out for one entire day. Finless tried to explain to me how to clear the presets but I still couldn't figure it out.
    Jul 2014
    Mint Hill, NC
    Mike, I was hoping when I changed my battery on my 14 RTS it would clear my radio setting because they were all screwed up...
    While it's a mite of a PITA you clear the preset stations by overwriting them.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    .... I don't use pre-sets, so I can't help ....... when I said " RADIO " I was referring to things like - balance - fade - vol. control etc. .... Mike
    Northern Kalifornia
    Thank you JayBros I will try that. It's not been a common subject discussed on this forum.
    Idaho
    IIRC, one way is to go into preferences and set the audio region to something other than US. Then tune the radio to a frequency that is nothing but static, overwrite each preset, and return region back to 1. I don't know if the presets will then all be silent or static.
    2014 Copper RTS
