Results 1 to 5 of 5
    Aug 2021
    Arizona
    Default Loss of power with a P1215 error code
    My first ride in a month. My 2019 900 ACE has been in a garage and on a tender the whole time. Started right up and took a few minutes to warm up. I got about 10 miles from home and it died. Instrument cluster went dark but still showed the numbers and levels.(Fuel and temp).
    After my meltdown on the freeway, I disconnected the battery and checked the fuses. (All were good).
    The only electronic mischief I have done is a model 3 Digital Dawg remote starter.
    After I called the tow truck, I reattached the battery. It started like nothing happened. I waved the truck off and drove home.
    My power vision 3 from dynojet reads a historical error code of P1215 but no current error codes. I purchased the service manual and it does not list any P12-- error codes.
    Thank you in advance. My only recent addition is a beautiful "Freedom" radiator protector from BLR tuning and it is hard to blame that. LOL
    George
    Arizona
    Last edited by Peter Aawen; 12-02-2021 at 03:39 PM. Reason: Added missing w's, n's, & y's. ;-)
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    For automotive applications P1215 varies:
    https://obdii.pro/en/code/P1215
    If it was more than a slightly loose connection at your battery which has a fair degree of probability, I would unplug and replug all the connectors that you can reasonably access.
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Active Member DickB's Avatar
    Jun 2021
    FL
    Here's a list of codes for Can-Am ATVs:
    https://www.can-amforum.com/threads/...ription.31491/
    P1215 Gnd Fault Detection Indicated
    May 2020
    New Mexico
    Quote Originally Posted by DickB View Post
    Thanks, DickB
    geosar: In the absence of specific service manual recommendations, post 2 advice is the same.
    You may have already made a correction by reconnecting the battery, but you may want to also check the engine/frame negative battery connection.
    Aug 2021
    Arizona
    Thank you for the help. I disconnected the battery and carefully reattached the negative terminal. Rode it yesterday afternoon with no issues.
    The Power Vision 3 error P1215 cleared with out my intervention.
    I appreciate the educated help.
    George
    Arizona
