Results 1 to 25 of 27
    Active Member boz329's Avatar
    May 2017
    Toledo Ohio
    Default Time to replace this tire?
    Just turned 12k miles on these OEM tires. I have noticed a little more action on some surfaces with the rear end, wanted feedback from submitted photos if it's time to replace. Is this wear pattern the usual?
    Aug 2020
    Il
    I believe wear pattern looks normal. Front tires look fine. Time to replace the rear one.
    Northern Kalifornia
    Don't see any cord showing yet. You maybe have another 10K to go. "NOT!" Get that thing replaced post-haste before it causes a huge problem for you and/or someone else. Check out the Tire Rack and do a search here to find out which tire you'd prefer, but get that thing changed out soon.
    That wear pattern is common for the rear tire on OE Kendas, Kenda Kanines, and the Vee-rubber clone Arachnids; and while you've done pretty well to get 12k miles out of it, it's now dangerously well past time to replace that rear tire!!
    However, the front tire shown, if there's no vibration or other unexplained handling issues occurring and you aren't out-ryding their (not necessarily all that wonderful ) grip all the time, looks to be good for a while yet!
    The bars you can see in the tread grooves of that front tire have a series of raised lines on the top of them, so they are NOT the Tread Wear indicators, but rather they are just tread stabiliser bars & rain/ice breakers intended to force collected rain/ice out of the grooves thru the siping. The 'real' Tread Wear indicators won't have those lines across the top; are usually about 8-10 inches further around the tread; and will have a small triangle embossed on the very edge of the tread where it meets the sidewall, with the pointy top of the triangle pointing towards the nearest tread wear indicator & not quite so directly towards the others as they are staggered across the tread grooves.
    Over to you!
    May 2017
    Mesa, Arid-Zone-A
    Look familiar?
    Semper Fi
    Durham,Maine
    Like the above have said, all looks normal, and yes, it's time to get some new sneakers on her!!!
    2012 RTL , Pearl
    INDIANA, USA
    Default Need a New Rear Tire
    YES, you need a new rear tire.
    Check out the tires on this Forum.
    General Altima RT 43 is a good starting point.
    There is a current posting on Rear Tire selection on this Forum. Check it out.
    I tried to get my Spyder Dealer to change out my rear tire for a 'better tire' but they were against using the tire.
    Something about 'BRP/the tire law'. ..... ...
    ENJOY YOUR LIFE WITH A SPYDER
    Nov 2018
    Trinity, NC
    I just replaced my OEM tires with the new Vredestein Quatrac's. My front and rear tires looked a lot like yours but I went ahead and replaced all 3. There was an amazing difference in the ride and handling. Wish I would have done it a lot earlier. I'm sure any of the recommended tires on here would work great for you.
    Cheers
    Bill
    Another vote for replacing the rear tire. It looks like it is past is useful time.
    western Colorado
    Front looks good. Rear looks over inflated
    Aug 2019
    southwest oHIo
    I will just say "if it's a Kenda, it' time to replace it."
    Even if it still has the molding tips of a brand new tire.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Quote Originally Posted by happyspyder2039 View Post
    While that will generally be the case for tread wear like that on any 'normal' tire, but it doesn't seem to make much of a difference on the Kenda &/or clone rears - they generally just wear like that regardless and usually fairly quickly too!!
    I reckon it's because they're so lightly constructed - lightweight 'rubber' everywhere; lightweight denier thread in the plies (2 tread & 1 sidewall); and lighter than most steel belts too! So because of that lightweight construction, once the tire starts rotating at any sort of speed, the centre of the tread gets thrown out, 'growing' the tire's rolling diameter but narrowing its contact patch, just like it does on a drag tire once it starts spinning up, so you end up ryding on the middle 2 inches of the Kendas tread and consequently wearing the centre out faster than the sides of the tread.... and giving you less traction than you are likely to get from a real auto tire with its heavier construction and a tread that's held flatter across its face, keeping more of it on the road surface more of the time, and levelling out the wear and improving the ryde & handling as a result!
    I humbly dis-agree .... Kenda REAR tires don't wear quickly because of the PSI in them .... they wear quickly because they of WEAK construction .... this allows them to balloon at speeds above 35 mph. ..... This only appears to happen to the REAR tires, not the fronts ..... WHY ???? ... because the rear is a wider ( 225 vs. 160 ) tire..... Mike .... I would delete this post if I could .... because Pater said itbefore I read His answer ......
    INDIANA, USA
    Default Replace this Rear Tire
    Quote Originally Posted by boz329 View Post
    Just turned 12k miles on these OEM tires. I have noticed a little more action on some surfaces.. with the rear end, wanted feedback from submitted photos if it's time to replace. Is this wear pattern the usual?
    Replace this rear tire asap. .......
    Active Member ChicagoSpyder's Avatar
    Chicago
    My rear tire looked like that at 6,000 miles, the inside of the front tire looks like it has a little cupping.
    I put a Kumho AST in the rear, it's just OK as it has less grip than the Kenda, I went with Vredsteins up front, good bite and a smooth ride.
    2018 F3 Limited , Black/Chrome
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    PLAN AHEAD!! There is going to be a shortage of tires that you can use on a Spyder next riding season.
    start looking for those replacements now.
    T.P.
    May 2017
    Mesa, Arid-Zone-A
    Quote Originally Posted by T.P. View Post
    T.P.
    The picture of my rear tire in post #5 of this thread was taken while I was on the road riding the bike from Tulsa, OK home to Mesa, AZ. I was a clueless new Spyder owner riding it for the very first time. When I took delivery the tires looked fine. Unknown to me the selling dealer aired the rear up to 35#s. That tire went from "looking fine" to what you see in the picture in just 700 miles of interstate speeds. My lessons learned (quickly). Kendas are crap! An overinflated Kenda will wear badly and very quickly at 60-70 MPH. So, it pays to plan ahead. Especially if you are riding on Kendas.
    And, BTW..... The dealer where I bought my Spyder (non-Spyder dealership) paid for a new tire and to have it installed when I was a little more than half way home. Guess they felt responsible for sending me out on the road with an unsafe tire. Stay safe..... Jim
    Semper Fi
    Jul 2010
    Las Vegas, NV
    New tires all around. Expect a wait. We waited 3 weeks for the last one.
    Joe Meyer
    Active Member sledge's Avatar
    Aug 2021
    Limestone Tn.
    i am putting new Car Tires on my 2011 RT before spring . has anyone put a 225/50 R15 on the Rear ???
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by sledge View Post
    225/50R15 is OEM I believe ! Go 4 it. Kenda or Kumho ?
    Aug 2021
    Limestone Tn.
    neither one , my wife bought me a complete set , for Christmas , I have not started taking the wheels off yet , but they sure look Impressive . and they should last for years . we all know the difference in Motor Cycle Tires....and Car Tires ... 10,000 miles will wear most motor cycle tires completely out , and a car tire same size will last at least 40,000 miles . motor cycle tires are softer rubber so they will stick in a turn better , but a trike don't lean into a turn , so they don't really need the softer tires .
    Feb 2020
    Minnesota,USA
    So ,, what Brand Tire did you get? You've got my attention ? They STILL NEED TO STICK!
    Vermont
    Replace rear tire!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Aug 2021
    Limestone Tn.
    ohhhhhh I think she bought Goodyear tires . I have not put them on the Spyder yet , I am gonna put them on myself , been looking at buying a tire/wheel balencer .
    Feb 2020
    Minnesota,USA
    Questionable, 225/50R15 in a Good Year brand ? They may make that size, but I don't believe it is something you want to put on your Spyder. Check in with Mike ,"The Blue Knight", He will get you on the right path too car spools.
