Results 1 to 8 of 8
    Jan 2019
    North Carolina
    Default Recommend any Blocks for front wheels in trailer?
    Hi folks, I just bought an enclosed trailer.
    Is anyone aware of a couple of blocks that I can mount to the floor in front of the tires that would probably keep the Spyder from moving from side to side?
    Thanks in advance.
    Quote Originally Posted by Jackhartjr View Post
    Thanks in advance.
    If your main concern is side to side ..... what will work fine is...., use a small piece of plywood then screw two short pieces of 2" X 2" to the front and one side of the plywood .... then when you load your Spyder roll it onto the plywood pieces and screw them to the floor. ... I use the Rachet over the tire method to keep the Spyder from moving , so this is an easy way of preventing movement. .... some folks take a 1/2 hr. to an hour tying their Spyders down .... I do it in about 10 minutes ..... good luck ..... Mike
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    IF you can find a set of these Spyder Super clamps for sale, get them. Once and awhile a set is for sale on here and well worth it.
    They no longer make these.
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Sep 2017
    Durham,Maine
    https://www.etrailer.com/s.aspx?qry=wheel+chocks Try these guys, they are not cheep, you can probably find some thing cheaper, but it's a start!
    2012 RTL , Pearl
    Apr 2019
    PA
    Quote Originally Posted by MeudtPG View Post
    Someone on this site has a pair for sale right now. https://www.spyderlovers.com/forums/...k-kit-for-sale
    Active Member WDAVEY's Avatar
    Jul 2019
    FL in winter, CNY in summer
    Not cheap, but I used two Condor motorcycle chocks. Very heavy duty and nice looking. I already had one from my Harley days so I only had to buy one additional. Position the Spyder in your trailer to achieve desired tongue weight of 10-12% of the trailer total loaded. Mark the exact location where the front tires need to stop.
    Jan 2019
    North Carolina
    Thanks to all that answered.
    I went with a nice pair from etrailer!
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    If you need wheel chocks WalMart sells them dirt cheap! that is where I got mine. bolted them to the floor of the trailer and have many thousands of miies with the Spyder on the trailer and no issues.
    BIG F
