Results 1 to 7 of 7
    Apr 2016
    Grass Lake MI.
    Default How many Oil Drain plug(s) on 2021 RT Limited? What size(s)?
    How many drain plugs are there in a 2021 1300 cc motor? If two are they the same?
    2021 RT Limited , Marsala Red
    Mar 2017
    Salisbury,NC
    2 - 45mm torx and 6mm hex. get a good look at them before trying to put tool in. found out they are NOT 90 deg to floor. just insert them fully to see the slight angle. I have NOT stripped them out. only tighten them tight, not with torque wrench
    Apr 2016
    Grass Lake MI.
    Thank you I had a 2014 RTS and it had two plugs, but they were different lengths.
    Mar 2017
    Salisbury,NC
    also they different threads and lengths, if i remember correctly
    Idaho
    Quote Originally Posted by Woodaddict View Post
    2 - 41mm torx and 6mm hex.
    You mean T45 torx, right? Torx has its own sizing system that seems to have no correlation to any mm or inch measurement scheme.
    2014 Copper RTS
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by leggsdad View Post
    Same motor, same plugs.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
