Pedal Commander vs Pedal Box - what's the difference?
What is the difference between the pedal commander and the pedal box?
They both do the same task - making throttle response more sensitive. Other than price, I doubt it matters which you go with.
Pedal Box is made near my home. I bought a Pedal Commander. Easier to see the setting and more.
Reason: mu = my ;-)
2021 Spyder F3-S Special Series
Monster Fuel Injection Stage II
K&N Air Filter
Lamonster Cat Delete Pipe with Baffle
Akrapovic Sinister Exhaust
Ultimate Floorboards
Baja Ron’s Anti-Sway Bar Kit
Elka Shocks Stage 3 Front, Stage 4 Rear
F4 Customs 32” Windshield
Pedal Commander
Lamonster F3 Brake Rod
Shad SH36 Side Cases
Crampbuster
I just received and installed the Pedal Box from Martin on my '21 RT. I am not an early adopter for most things but I will say I am quite happy with the new performance of the RT. I will likely run this in one of the Sport modes. My first impression is that the power is more readily available and keeps me more involved with the machine. Very simple operation. May look at concealing the device under the tupperware and using the phone app to select the mode. In the meantime it is attached to the center post and out of the way.
It seems we are still waiting for someone with an understanding of both to weigh in on the differences. I've done a little Googling and came up with this;
Pedal Box and Pedal Commander both improve throttle response of a fly-by-wire system such as the Spyder (and Ryker) have. There is no change in the ECU so the Air / Fuel Ratio is not affected (as it is with an ECU Flash).
Probably for a combination of safety and fuel economy reasons, the OEM throttle response system is slower to respond to a twisting of the throttle grip; these devices (PB & PC) give the rider greater control over the amount of delay or sluggishness built into the system. From what I can tell, the OEM throttle controller does open the throttle 100% when fully opened, but only briefly after which it dials back the throttle opening to 90% or so regardless of what the rider is doing with the throttle grip. With the Pedal Box and Pedal Commander, the rider directly controls the amount of throttle opening, overriding the OEM 'nanny'.
Both PB and PC are currently (July 2022) priced at $300 but the PC includes the phone app in the price and PB charges an extra $50 for it.
Apparently, Pedal Box is available only for the F3 models of Spyder; https://www.pedalbox.com/us/can-am/s.../pedalbox.html
Pedal Commander is from SlingMods.com and is available for all engines of the Spyder and Ryker line I think; https://www.slingmods.com/canam-spyd...edal-commander
2014 RTL Platinum
UtahPete, nice research and description. Thanks!
guess this is not an option for a 2013 Spyder ST
Ozzie Ozzie Ozzie
