Results 1 to 9 of 9
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default Pedal Commander vs Pedal Box - what's the difference?
    What is the difference between the pedal commander and the pedal box?
    2022 F3 Limited , Monolith Black / Dark
    Sep 2020
    Middletown, NJ
    They both do the same task - making throttle response more sensitive. Other than price, I doubt it matters which you go with.
    2020 RT base , Chalk White
    Feb 2019
    Portland, Oregon
    Pedal Box is made near my home. I bought a Pedal Commander. Easier to see the setting and more.
    Active Member RobDekker's Avatar
    May 2021
    New Brunswick, CANADA
    2021 Spyder F3-S Special Series
    Monster Fuel Injection Stage II
    K&N Air Filter
    Lamonster Cat Delete Pipe with Baffle
    Akrapovic Sinister Exhaust
    Ultimate Floorboards
    Baja Ron’s Anti-Sway Bar Kit
    Elka Shocks Stage 3 Front, Stage 4 Rear
    F4 Customs 32” Windshield
    Pedal Commander
    Lamonster F3 Brake Rod
    Shad SH36 Side Cases
    Crampbuster
    Oct 2020
    KS
    I just received and installed the Pedal Box from Martin on my '21 RT. I am not an early adopter for most things but I will say I am quite happy with the new performance of the RT. I will likely run this in one of the Sport modes. My first impression is that the power is more readily available and keeps me more involved with the machine. Very simple operation. May look at concealing the device under the tupperware and using the phone app to select the mode. In the meantime it is attached to the center post and out of the way.
    Dec 2015
    Oakley Utah
    It seems we are still waiting for someone with an understanding of both to weigh in on the differences. I've done a little Googling and came up with this;
    Pedal Box and Pedal Commander both improve throttle response of a fly-by-wire system such as the Spyder (and Ryker) have. There is no change in the ECU so the Air / Fuel Ratio is not affected (as it is with an ECU Flash).
    Probably for a combination of safety and fuel economy reasons, the OEM throttle response system is slower to respond to a twisting of the throttle grip; these devices (PB & PC) give the rider greater control over the amount of delay or sluggishness built into the system. From what I can tell, the OEM throttle controller does open the throttle 100% when fully opened, but only briefly after which it dials back the throttle opening to 90% or so regardless of what the rider is doing with the throttle grip. With the Pedal Box and Pedal Commander, the rider directly controls the amount of throttle opening, overriding the OEM 'nanny'.
    Both PB and PC are currently (July 2022) priced at $300 but the PC includes the phone app in the price and PB charges an extra $50 for it.
    Apparently, Pedal Box is available only for the F3 models of Spyder; https://www.pedalbox.com/us/can-am/s.../pedalbox.html
    Pedal Commander is from SlingMods.com and is available for all engines of the Spyder and Ryker line I think; https://www.slingmods.com/canam-spyd...edal-commander
    2014 RTL Platinum
    Jan 2022
    Tennessee
    UtahPete, nice research and description. Thanks!
    Active Member RangerRick's Avatar
    Jul 2022
    Coos Bay, Oregon
    guess this is not an option for a 2013 Spyder ST
    Quote Originally Posted by RangerRick View Post
    I don't see why you couldn't get some version of this sorta gear that'll work on your 2013 ST, even if not necessarily made/retailed by either of those mobs mentioned above!
    The 2013 RS/ST/RT Spyder's all got the same 'drive-by-wire' throttles that the 2014 & later Spyder & Ryker models have, which is basically just like most other modern computer enhanced vehicles. So even if the 2013 ST isn't listed on a particular retailer's product blurb, there still should be something out there that is suitable, and probably something that either plugs directly into the 2013 Can Am loom or that can be made to plug in/wire into the 2013 loom to work in exactly the same manner as those products for the 2014 & on units do! . I wouldn't even be surprised if the solution didn't end up being exactly the same product, just fitted with plugs that have been confirmed to match the plugs & wiring on the 2013 models!
    But I guess you'll never know unless you ask - or find someone who's game to try it out!!
