Originally Posted by Papa103
I don't think I've ever gotten 40 MPG with my 2019 RTL or my 2021 RTL. If I'm driving off interstate 60 mpg and under using 6th gear when over 50 MPH I will get high 30's. Interstate driving 75 and up (in 6th gear) I will be in the mid to upper 20's.
I ALWAYS fill to the lip/ring on the tank .... when filling I ALWAYS record how much gas fits in AFTER the auto shut-off engages ... this amount is 1.3 to 1.4 gals..... ALWAYS ..... Mike
FWIW, I use an app called, "ACar" on my phone to track all fuel usage and service intervals. It's free. It will give you a much better idea of actual fuel economy.
My 2019 RTD gets 35 when driving under 60. As soon as I get on the interstate the DTE goes down about twice as fast as normal. Then when I slow down I can actually gain miles on the DTE for the next couple of hours making it look like I'm not even using gas.
I don't know what its actually getting when driving the turnpike but it must be like half as much. at 75 it just sucks it down. I don't know how any of you guys do the long distance. That would drive me bonkers. So I try to stay off the highway anyway as there is no way to keep up to traffic even at 75. Cars are now going 80-90 now a days.
I'll mention that 6th gear also felt a little funky (hard to describe)
"I'll mention that 6th gear also felt a little funky (hard to describe)"
Low mileage 3-year old Spyder: add a full bottle of fuel injector cleaner next fill.
Drive until Low Fuel light.
Then use regular gas (minimal ethanol if possible) for next fill.
Drive a half-tank. Did funky go away?
I don't know 2019 dashboard but if it has bars how many show when Low Fuel light appears?
My 2014 is 1 sometimes 2 bars.
Wow! I didn't realize how I was short changing myself! Thanks Mike!
~Sandee~
2016 RT-L (Purchased used in February 2018)
RT Dash Mount (from JT's Spyder Store)
Kuryakin Trident Highway Pegs
Hopnel Pouch
Magic Mirrors
Spyderpops Foam Handgrips
Iron Butt #35273
Girls on Spyders #2779
I'm wondering how riding in Eco Mode fits into this equation? Does it improve or hamper MPG?
Greg Kamer
USAF, 20 years, retired
2018 Can Am Spyder RT-Limited
SpyderLovers Ambassador
I have only gotten one or two extra miles to the gallon using 'Eco Mode'.. This for me is not a game changer.
Do what you want and enjoy some ryde time....
ENJOY YOUR LIFE WITH A SPYDER
I cruise with traffic at normal highway speeds. When I accelerate I tend to shift up at around peak torque and don’t bother revving it out to the redline. I usually ride 2 up.
You have to consider, an RT LTD ways about 1,000 lbs plus riders. It might look sleek but it has the aerodynamics of an RV trailer. The tires are wide and run low pressure. It has a flat underbody 4 inches off the ground which probably creates a lot of drag from the resulting down force related drag. Then there are potential frictional losses and a basic engine technology not designed with things like V-Tech in mind.
My Triumph Trophy TTSE had a similar motor, but it revved more and made lots more power. But with 350 pounds less, much smaller frontal area, two much slimmer inline tires, it would manage mid 30 mpg at 20 mph faster. It had a tall top gear though.
So 35 mpg on the freeway at 75 mph would seem not too bad in comparison, and that’s what I see. It is a touring machine after all and was probably designed for a vastly different purpose to the high speed mileage eating Triumph.
The rotax motor is designed on the side of basic for a reliable high mileage life, so high technology systems for greater engine efficiency at the cost of engine life were probably not in the equation. You get hint of that from the low redline rpm’s.
I think they could have built a better fuel tank, with slight more capacity and a better filler neck. I can’t even fill up with the Costco pumps any more as to keep the activation sleeve pushed back by the filler the nozzle goes in so deep the tank has about 2 gallons of free space left. That costs me more than the fuel consumption as I have to go to more expensive stations.
Can Am Syder RT Limited (2021)
Triumph Bonneville T120 (2018)
Do like I do. Pull the nozzle out like you did before and grab hold of the sleeve and pull it back. Then gas flows! I fill my tank to the brim that way!
There are also cards to hold the sleeve back out of the way.
Aerostich - https://www.aerostich.com/gascard.html
Adventure Rider - https://www.advrider.com/f/threads/v...#post-44190291
2023 Ryker Rally - Heritage White III
Sport Windshield
GPS Holder
Originally Posted by StalkyTracker
Kind of neat!
ECO mode, if used faithfully, will give you about one extra MPG. It will also slow down your power curve.
The "ECO mode " is calibrated to improve gas MPG's ..... IMHO if you are on the interstate and keep it a steady speed ( whatever number you chose ) it will make a difference in your MPG's. However, trying to compare it to a different Trip is really impossible. The calibration they set it for is only " theoretical ". Google " EPA " testing procedures, it will explain how it's done. However No One can actually drive this way. If you put a veh. on a Dyno type machine you can get pretty consistent measurements because the parameters will be constant. ... actual driving will produce Hughley different numbers ..... hope this helps .... mike
Tags for this Thread
