Results 1 to 11 of 11
Thread: Over Heating
    May 2021
    Iowa
    Default Over Heating
    I have a 2014 RT-S Have owned it for about five months and put on quite a few miles. I just started having problems with the temp gage going into the danger zone and the red temp light coming on. I have checked the fluid level and am ok. I checked the radiators and nothing blocking them. As long as I stay moving, the gage stays put but when I stop and idle, it eventually goes high and the red light comes on. I start moving and it all clears up. Nothing ever steams or feels hot but it's really hard to tell with everything covered like it is. I am thinking it must be either the temp sending unit or the module that is controlling the temp. Anybody had similar problems and have a solution or ideas?
    Mar 2013
    Marion, Arkansas
    Have you check to make sure your electric fans are coming on?
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Active Member cravenfun's Avatar
    Oct 2021
    Old Forge, NY
    Overheating when stopped sounds like the fans are not coming on when your stopped.
    Moving forward push's air through the radiators, fans are needed when stopped. Check the fan for something in it first and that it's turning freely.
    John
    "some suffer from insanity, I choose to enjoy it"
    '15 F3S SE6
    '01 FLHR
    Ski Doo 1200's
    Boats
    2015 F3S SE6 , Magnesium
    May 2021
    Iowa
    Fans are coming on. Okay, at least one is since the noise is the only way I know to check. What all would I have to tear apart to check the fans. Can't just open the hood.
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    The fans should engage long before it pings a red light.
    May 2021
    Iowa
    Oh they come on long before the red light comes on but how would I know if both are coming on?
    Jan 2021
    Descanso, CA
    Bikerinia -- the fans (there are two, one for each radiator) are bi-directional. They are controlled by several relays. First step is to walk through fuses and relays with the information in your owner's manual. If you don't find the problem, then next step is to buy a service manual and trouble-shoot from there.
    The normal temperature in almost all conditions is 4 bars. As Jheck noted, the fans will come on idling in traffic with temperatures in the 70s. I believe they exhaust forward at that time to keep the heat away from the rider's legs but never bothered to confirm. Easy to feel by hand.
    If you haven't replaced the coolant, now is the time as the water pump and thermostat are an expensive integrated assembly.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    May 2021
    Iowa
    Next time the fans are on I'll check an see if they are both blowing out the front, thanks for telling me that. I think it is not really over heating but just that it has a bad module or sending unit
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Is there more than one temperature sensor on the Spyder?
    This could help determine if temperature sensor(s) are an issue.
    https://www.harborfreight.com/121-in...ter-63985.html
    However, based on fan noise before overheating, more than likely that the second fan is not engaged.
    Check for both fans operating before doing anything else.
    An infrared laser thermometer can be pointed at radiator or water pump or head(s) to compare temperature with specs.
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    May 2021
    Iowa
    So how would I use that temp sensor gun to check the temp? So it would tell you the exhaust air temp from either side? As long as each fan was working right?
    Mar 2015
    forrest above Reno, Nv
    . Check out my posts on overheating--- long ,long story short, water pump failed and the replacement had an internal leak.
    https://www.spyderlovers.com/forums/...ns+running+lot
    2014 RTS , Circuit Yellow
