Results 1 to 6 of 6
    May 2021
    Acworth, Georga
    Default 2021 F3L won't start after headlight replacement
    I just installed new LED headlights from Lamonster, now the bike wont start. Battery is strong and cranks good just wont start.
    Any thoughts on what I screwed up this time
    Jun 2021
    OR
    Did you remove the frunk? I believe there are a couple of sensors on it, did you reconnect them?
    Mar 2017
    Salisbury,NC
    just have to ask to eliminate sequence, is kill switch been turned / bumped to OFF?
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Quote Originally Posted by Woodaddict View Post
    If kill switch is OFF, it will not even crank!
    2018 RT LTD , Black
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    If you disconnected the battery, make sure you got all the connectors back on the correct terminals.
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Netherlands
    It may be the new headlights, they may consume too much power. Met a guy with same issue and after quite some time the only thing left, what did I change? He disconnected the headlights to test and guess what, it started straight away. Connected headlights again and it did not start. Worthwhile to check it out
    2020 F3S , Matte black
