Results 1 to 5 of 5
    Nov 2019
    Kansas
    Default 18 F3L: issues removing the frunk?!?
    Trying to remove the frunk and running into issues. It looks like the top grey piece covering the computer connection, is over the top of the frunk piece where the lock goes in. So I do not see how to get the frunk out without breaking the greay piece..advice?
    Jul 2010
    Las Vegas, NV
    Pull up on the piece. It removes. Are you taking off the whole frunk, or, the frunk bucket? The bucket comes out with 4 pushpins. Remove the panel, bucket lifts out. Call me if you need help. Joe
    Joe Meyer
    Registered Users Motogordo's Avatar
    Jun 2011
    Delanco, New Jersey
    The gray piece just lifts out. Just pull up on the back corners and up it comes.
    Mar 2017
    There are raised panels on each end. Insert finger from the front and lift. Get some plumbers grease and put on the pins to make it easier to do next time. Lifting from the rear of the panel will just have it hitting the upper cowl/headlight and it won't come out (on the F3 at least).
    Active Member cravenfun's Avatar
    Oct 2021
    Old Forge, NY
    I use a silicone grease, like spark plug boot grease, on all my PITA sticky rubber grommets on vehicles and my toys.
    John
    "some suffer from insanity, I choose to enjoy it"
    '15 F3S SE6
    '01 FLHR
    Ski Doo 1200's
    Boats
    2015 F3S SE6 , Magnesium
