Results 1 to 8 of 8
    Active Member KnurledNut's Avatar
    Jul 2021
    Favoretta, FL
    Default Bad LED Retention rings from Slingmods
    Slingmods includes a pair of "can-am ryker locking headlight-retention-rings" to make the H4 LED upgrade 'plug & play'.
    The tolerances of their retention rings are terrible. You can see the movement and hear the click of the retention ring. The ring should snap in place.
    In addition the Ryker's headlight housings need to be removed to install the driver's side LED. Another strike against this being a 'plug & play' upgrade.
    If these LED lights last 2-3 months I'll be lucky. What a total waste of $65.
    2021 , generic
    Jul 2021
    PA
    thanks for posting this. Just so you know the video can't be watched here only on the tube.
    Aug 2019
    Stoughton, WI
    And to be clear, you purchased the item from Slingmod's, but the piece is manufactured by TricLed. TricLed has awesome CS. Maybe contact them?
    2022 RT Sea To Sky
    Feb 2019
    Portland, Oregon
    Did you contact Slingmods customer service with this problem? What did they say?
    Danbury Connecticut
    I can understand your frustration. Did you contact SlingMods for a solution before you posted here ?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Jul 2021
    Favoretta, FL
    Quote Originally Posted by Beginner View Post
    Thanks, I removed the video to keep from linking elsewhere.
    2021 , generic
    Invalid Emails
    May 2021
    Ontario,New York
    I was not impressed with the retention rings either. So far (I installed this summer) they have held up though.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I bought a set of the LED's from SlingMods this summer. On my set the bulb adapter flange was metal (like the stock halogen bulb) instead of plastic. I did not try to use the retainment ring provided in the kit because the stock ring worked fine (just like it did on the stock halogen bulb). So far everything has worked fine and I tested them on a long after-dark ride last night. Much better illumination than the stock halogens.
    If you have the metal flange on the bulb adapter try the stock retaining ring.
    2019 Ryler Rally , Shock Yellow
