Results 1 to 5 of 5
    Dec 2015
    Australia
    Default 2010 RT SE5 digital gauges working and volt gauge hooked up
    Hi Guys", I disconnected analogue gauges and put in a digital volt gauge too.
    Now I will see how accurate the digital gauge is.
    Last edited by Peter Aawen; 10-27-2021 at 02:59 AM. Reason: Removed Prefix - not engine/size related
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Did the same thing to ours with the same gauge. It will also show you, are your battery gets older and worn down when you need to replace it because you can watch the voltage drop under load when you go to start it.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Feb 2012
    Spring City,Utah
    Nice job Peter.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2015
    Oakley Utah
    Quote Originally Posted by peterRT View Post
    Looks nice. What did you put in the other hole?
    2014 RTL Platinum
    Durham,Maine
    Nice!!!!
    2012 RTL , Pearl
