Winter Storage - any problems if I remove the battery?
Have to store my 2019 F3 ltd in unheated pole barn this winter. Just wondering if it would cause any problems if I removed the battery over the winter.
2019 F3 Limited, Black with Wrap My Spyder red racing stripes
BajaRon sway bar
La Monster LED headlights
LED fog lights
F4 Customs 21" tinted windshield
Ultimate red trimmed seat/driver backrest
Ram quick grip phone holder
Cardo Packtalk Bold headsets
Not a bad idea if you don't have power to the storage area. It shouldn't cause any problems while it sleeps out its winter storage. Otherwise, just keep it covered to protect it from the elements and if you have power, hook up a battery tender to the battery and you should be good to go. The first winter I owned my spyder I had to store it in a similar situation. Remember to keep the cover tied down so the neighbor's cats can't climb up under it and sleep on the seat. Also, place a couple of bars of Irish Spring soap under it to keep the little varmints away. They don't like the smell, but they do like to build nests in your spyder if they can. They also like to chew on the wiring.
Rodent control (poison) companies make small plastic boxes to hold bait blocks. I've kept one in the trunk of our GL1800 and now the RTL. Ever since doing so, no evidence of mice in the bike. However, I've found the only effective control of chipmonks (ground squirrels) has been a 1/2-water filled sheetrock mud bucket with a handful of sunflower seeds spread over the surface. Remove the accumulated non-swimmers each day, put in a grocery bag, and drop off at the nearby convenience center. Takes a couple weeks to clear out a colony. Repeat when necessary.
"Love 'em all.... Let GOD sort 'em out!"
2021 RTL Dark Chalk Metallic with comfort seat
1978 GL1000 w/'75 engine show bike
1976 RD400c
A very good friend of mine ( who is a master mechanic ) re-moves every Battery from every vehicle He is not using in the winter ..... and stores them in a climate controlled ( heated ) area .... He often gets 10 + yrs from His batteries ...... I do the same ..... good luck .... Mike
I think you're asking whether the Spyder electronics can survive being without a power source for that long. I don't think it's a problem, but I don't know for sure. I'm considering doing the same, so curious what others have to say. From Mike's post, it would seem it's okay, even preferred.
2014 RTL Platinum
Also,
Contact your motorcycle insurance company, your premium maybe reduced. Check with your motorcycle insurance company.
I put my spyder in hibernation ( from Oct. to April). But I keep the battery in the spyder.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
I use a 50/50 mix of anti-freeze in my buckets. Keeps dead smell down a lot when you can't scoop out the carcass's for a few days in warmer temps and doesn't freeze if in a cold climate.
John
"some suffer from insanity, I choose to enjoy it"
'15 F3S SE6
'01 FLHR
Ski Doo 1200's
Boats
Haven't heard about the Irish Spring soap. I have tried moth balls and dryer sheets before. Will pick up some soap bars and give it a shot.
Do not use poisons or 50/50 antifreeze, You can harm your and your neighbor's pets.
I only use that mix in a closed building so my pup doesn't get into it. Plus using the bucket lid with a small access hole is added pet protection.
Those critters get in without a problem.
Safety first just like using the bait stations for the mouse blocks.
John
'15 F3S SE6
'01 FLHR
Ski Doo 1200's
Boats
SpyderLovers Sponsor
Yes, remove the battery. It will be fine. Put in neutral, parking brake off, chock wheels. Then remove battery, place in a heated area, place on a battery tender. Won’t hurt any of the electronics.
Joe Meyer
Poison no matter how it's applied does not discriminate. Sadly, a neighborhood issue nearly erupted in violence because a well-intended neighbor used poison to eradicate a varmint problem and more than one pet succumbed to its use. It was an unintentional and accidental mishandling of the poison. Personally, I would never use it after witnessing the results and the broken hearts it caused. Be careful my friend, please be very careful.
I think I will store without battery for the winter, why leave the parking brake off?
BajaRon sway bar
LED fog lights
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
"Put in neutral, parking brake off, chock wheels." Excellent idea.
I don't winterize. I have heated gear (make your own -> https://www.rattlebars.com/heated/) and find a way to ride all year 'round (much easier now since I have a winter home in SC ) If there is no ice no problem. Good on my GL1800 and now F3T.
PS: I have an old walmart Schumacher battery "tender" and believe it or not, it's the only charger that will revive a completely dead battery. Have three other "chargers" that won't. Never gonna toss that one that will.
It doesn’t work they just eat it. moth balls work the best.
Reason: spaces
Pulled the battery out of mine didn’t give it a second thought. did the same with my sleds in the spring when I had them. made sure they were charged up. didn’t keep on charges during the time they were sleeping. (I’m cheap didn’t want to pay extra hydro)
Reason: spaces :-/
Most of the above except the use of poisons. Don't forget to cover the exhaust with a plastic bag and rubber bands!
It's too tempting a home for some critters!
