Results 1 to 9 of 9
    Mar 2019
    Southern CA
    Default Spyder RT Heated Seat
    Selling a well made custom Hartco International seat from our 2018 RT Limited. Seat and backrest has an alligator pattern and is heated for both rider and passenger with two level heat settings. Also has the fuel door installed. Will fit the 2018 and 2019 model years of the RT and may fit earlier RT model years, though you will have to verify seat compatibility.
    Bought this with the intent to do lots of traveling, but moved and ended up not using the Spyder as much. Recently sold the RT with the intent to take our riding in a different direction. This seat has less than 300 miles of use. Was custom made for a shorter rider (4’ 11”, though will likely be OK for riders up to 5’5” and others with shorter inseams up to 29”). Comes with seat, backrest, and backrest pouch (not pictured) for small items. Will need to use hardware such as spacers, slam latch, shock mount, and passenger sensor from OEM seat when mounting. You will also need to wire this up to your bike. I can offer suggestions based on how I had it wired up to our bike if you wish.
    Pictures of seat along with how it looked mounted. Was over $1500 new. Asking $750 plus shipping. If you are local to the LA area you are welcome to come by to check it out. Just IM me if interested.
    Mar 2019
    Southern CA
    Bumping to top of list.
    Dec 2013
    Are you still trying to sell this Custom Made, Alligator pattern covered, heated RT seat with fuel door & backrest Wiggy??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2019
    Southern CA
    Yes, thanks for the bump. Please let me know if you’re interested. Super nice seat.
    Dec 2013
    Sadly, freight to Oz atm would make this seat cost almost as much as a replacement Spyder!
    But at least you got a bump & now local readers will know it's still for sale!
    It might help you to check out the 'How to use this sub-Forum' sticky at the top of the index too...
    Mar 2019
    Southern CA
    Bumping to the top.
    Mar 2019
    Southern CA
    Bump with price drop.
    Mar 2019
    Southern CA
    Bump.
    Dec 2015
    Oakley Utah
    Very nice seat for anyone with shorter legs / reach.
    2014 RTL Platinum
Tags for this Thread
